Awd Suspension/Tire Question http://4g61t.org/forum/viewtopic.php?f=57&t=37643 |
Page 2 of 2 |
Author: | xxNocturnalxx [ Tue Jul 30, 2013 12:57 am ] |
Post subject: | Re: Awd Suspension/Tire Question |
What specs did you end up getting?! |
Author: | Bet [ Tue Jul 30, 2013 3:36 am ] |
Quote: What specs did you end up getting?!
15x7.4 40+ Rota Slips & Some MT ET streets 2 Picking up some 24.5 slicks also I was gonna try 26' but idk if they will clear 225's also all the way around |
Author: | xxNocturnalxx [ Tue Jul 30, 2013 4:21 am ] |
Nice, I'm pretty sure 26" will hit quite a bit before lock. |
Author: | Bet [ Tue Jul 30, 2013 5:55 am ] |
Quote: Nice, I'm pretty sure 26" will hit quite a bit before lock.
hmm talking on facebook & 61t are we?
Author: | xxNocturnalxx [ Fri Aug 02, 2013 2:41 am ] |
Yes, I am just so excited about your car |
Author: | Bet [ Sun Aug 04, 2013 4:29 pm ] |
Quote: Yes, I am just so excited about your car
Lol so am I, I am waiting on my turbo feed & drain fittings, water to air setup, my 75mm TB, & all my SS line & fittings, then I can start putting it back together. |
Author: | installer88 [ Mon Aug 12, 2013 9:55 pm ] |
I figured I would ask this here instead of starting a new thread. With my fwd setup, I am running 17x8 +38. Currently they have 245 40 r17 and only scrub a little in the rear. The fenders are all rolled, but not pulled. Once the tires I have are done, 215 40 or 225 40 will replace them to make the overall diameter smaller, and to eliminate the scrubbing. My question is simple, when I install the AWD subframe, will I need higher offset wheels for the rear, or will the smaller tires and the ability for negative camber be enough. I only want to run 1-2 degrees negative in the rear. |
Page 2 of 2 | All times are UTC-05:00 |
