Awd Suspension/Tire Question http://4g61t.org/forum/viewtopic.php?f=57&t=37643 |
Page 1 of 2 |
Author: | Bet [ Wed Mar 27, 2013 3:33 am ] |
Post subject: | Awd Suspension/Tire Question |
After searching i just want to make sure I am correct. Alright my car "89 colt" has a AWD swap from a 91 gsx. So i am under the assumption that any 1g AWD suspension/coilovers will work? & for the fronts since everything is almost untouched i can just pick up any suspension items for my 89 & it will bolt on correct? & for tires i plan on just using the stock 1g wheels & running 205's or possibly picking up a set of wheels 15x6 or 15x7 with a -0 or -12 off set & running something a little wider. Just looking for opinions of what would work best for me. I am currently deployed & am trying to get everything together before i return. Thanks |
Author: | xxNocturnalxx [ Wed Mar 27, 2013 6:31 am ] |
Post subject: | Re: Awd Suspension/Tire Question |
If you want to push wider you should be able to get away with 225/50s on a 15x7 but i wouldn't go lower than +32 offset. My future set-up is going to be 205/50s on 15x6.5 +38 I've calculated it out to be fairly flush. Editing this because I ended up doing 225/50 on 15x7 +34 , rear is flush, front sticks out a tad. |
Author: | Bet [ Wed Mar 27, 2013 7:25 am ] |
Quote: If you want to push wider you should be able to get away with 225/50s on a 15x7 but i wouldn't go lower than +32 offset. My future set-up is going to be 205/50s on 15x6.5 +38 I've calculated it out to be fairly flush.
Alright thanks, i thinking of 225's originally but i didn't know how well they would fit & if i would get rubbing problems. I was originally going to run my rx7 wheels but they are 16x7 & +50 offset
Author: | CaptainTonus [ Wed Mar 27, 2013 10:18 am ] |
Quote: Quote: If you want to push wider you should be able to get away with 225/50s on a 15x7 but i wouldn't go lower than +32 offset. My future set-up is going to be 205/50s on 15x6.5 +38 I've calculated it out to be fairly flush.
Alright thanks, i thinking of 225's originally but i didn't know how well they would fit & if i would get rubbing problems. I was originally going to run my rx7 wheels but they are 16x7 & +50 offset225/50 might still rub, unless you do some fender-rolling. |
Author: | Bet [ Wed Mar 27, 2013 10:57 am ] |
Quote: Quote: Quote: If you want to push wider you should be able to get away with 225/50s on a 15x7 but i wouldn't go lower than +32 offset. My future set-up is going to be 205/50s on 15x6.5 +38 I've calculated it out to be fairly flush.
Alright thanks, i thinking of 225's originally but i didn't know how well they would fit & if i would get rubbing problems. I was originally going to run my rx7 wheels but they are 16x7 & +50 offset225/50 might still rub, unless you do some fender-rolling. Thanks, my mistake & I'm not against rolling my fenders. I should prob do it before i dip my car |
Author: | slowdsm [ Wed Mar 27, 2013 1:08 pm ] |
arent stock 1g rims 16" ? mine are Steve |
Author: | CaptainTonus [ Wed Mar 27, 2013 2:28 pm ] |
Quote: arent stock 1g rims 16" ? mine are
Stock 1g rims are 16x6" I believe, i think +46 offset
Steve |
Author: | dan [ Wed Mar 27, 2013 3:17 pm ] |
+43 on a 15x7.5 rim with 225/50 BFGs: I had to remove material from the lower rear spring perches and I rub on the trans with tight right turns. |
Author: | Bet [ Thu Mar 28, 2013 3:09 am ] |
Thanks for the picture, that car looks nice ^ Good to see what they will potentially look like. Assuming its AWD by the 225's all the way around, what did you choose as far as suspension & brakes go Edit* going to order a custom set of these today http://www.diamondracingwheels.com/inde ... eet-wheels 15x7 or 7.5 & with +40 offset. |
Author: | dan [ Thu Mar 28, 2013 9:45 am ] |
Yes, AWD. Stock brakes, stock front suspension (GR2s), and stock rear 1G AWD (GR2s). Quote: Thanks for the picture, that car looks nice ^ Good to see what they will potentially look like. Assuming its AWD by the 225's all the way around, what did you choose as far as suspension & brakes go
Author: | Bet [ Thu Mar 28, 2013 10:27 am ] |
Quote: Yes, AWD. Stock brakes, stock front suspension (GR2s), and stock rear 1G AWD (GR2s).
Quote: Thanks for the picture, that car looks nice ^ Good to see what they will potentially look like. Assuming its AWD by the 225's all the way around, what did you choose as far as suspension & brakes go Edit* going to order a custom set of these today http://www.diamondracingwheels.com/inde ... eet-wheels 15x7 or 7.5 & with +40 offset. Thanks, i really do appreciate the help |
Author: | Bet [ Fri Mar 29, 2013 11:26 am ] |
Dan i sent you a PM |
Author: | Bet [ Mon Jul 29, 2013 10:37 pm ] |
Quote: +43 on a 15x7.5 rim with 225/50 BFGs:
I had to remove material from the lower rear spring perches and I rub on the trans with tight right turns. Got my rims & tires ordered today. Thanks again for the help, can't wait to test fit them |
Author: | dan [ Mon Jul 29, 2013 11:18 pm ] |
Post some pics! |
Author: | Bet [ Mon Jul 29, 2013 11:30 pm ] |
Quote: Post some pics!
I will, I still gotta install my top mount, turbo, wheels, setup the gauges, fuel pump, etc etc. This car is pushing the limits of a "street" car |
