It is currently Thu May 09, 2024 7:02 am
 Post subject: Awd swap parts list.
PostPosted: Tue Jun 26, 2012 12:42 am
Buying a donor 1g talon awd to swap my Colt. Can anyone give me a parts write up of what I need from the talon?
 Post subject: Re: Awd swap parts list.
PostPosted: Tue Jun 26, 2012 2:03 am
Because Race Car
Here's everything you need for the front wheel drive swap to a 4G63T:
http://www.4g61t.org/forum/viewtopic.php?f=23&t=1303
From the rear end you need the complete subframe with suspension arms, uprights/hubs, axles, axle cups, diff, diff hanger, driveshaft - pretty much unbolt the driveshaft, shocks, and the four bolts (2 subframe, 2 diff hanger) from the rear end on the donor car and hold onto it. Some people reuse the subframe bolts... others go it alone. Your choice :)
PostPosted: Tue Jun 26, 2012 3:01 am
So I can't use the tranny from the talon?
PostPosted: Tue Jun 26, 2012 11:37 am
Because Race Car
Yes, you use the tranny from the Talon. That first link was just for swapping a Colt and remaining FWD. Use the AWD tranny/t-case from the Talon.
PostPosted: Wed Jun 27, 2012 5:31 pm
Does anyone have an idea of where I can get the crossmember and motor mounts built for me?
PostPosted: Wed Jun 27, 2012 7:37 pm
do a search on AWD crossmember
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Tue Aug 07, 2012 2:48 pm
I'm planning to do the same but im a little stupid amd need step by step guide on how to do it as i have a full donor car with all the necesaary parts.
PostPosted: Thu Nov 01, 2012 11:23 am
Once upon a time there was a DVD, step by step, full parts list......
Jason, still have any of those? Looks like you might have a customer.....
