AWD subframe mount dimensions (quick reference) http://4g61t.org/forum/viewtopic.php?f=57&t=35311 |
Author: | UnderPSI [ Wed Sep 14, 2011 4:46 pm ] |
Post subject: | AWD subframe mount dimensions (quick reference) |
Here is a quick reference of the 1g subframe mounting points that I made. I thought this would be helpful for someone who doesnt have one readily available. |
Author: | whe3ls [ Sat Sep 17, 2011 9:56 pm ] |
Post subject: | Re: AWD subframe mount dimensions (quick reference) |
you should add the distance between the middle of the mounts for the front back mounts |
Author: | UnderPSI [ Sun Sep 18, 2011 2:37 am ] |
Quote: you should add the distance between the middle of the mounts for the front back mounts
I dont quite understand your reply? I could get the measurements diagonally from front to back.
Author: | j2dapo [ Sun Oct 09, 2011 8:16 pm ] |
Awesome. Thanks, I needed this today. But I think you have the distances swapped the front of the bomerang is longer than the mustache bar. |
Author: | UnderPSI [ Sun Oct 09, 2011 11:31 pm ] |
Thanks for catching that! It's wonder nobody caught that sooner! |
