91 sedan swap. http://4g61t.org/forum/viewtopic.php?f=57&t=35222 |
Page 3 of 4 |
Author: | miragesist [ Wed Jun 20, 2012 10:40 pm ] |
Post subject: | Re: 91 sedan swap. |
carajoooooooooooo felicidades no habia visto este projecto,, so you went AWD,,, buena suerte its looking good |
Author: | LILEVO [ Tue Sep 24, 2013 4:35 pm ] |
The gvr4 tank is the one to use flipped 180. It is flat on top = sheet metal flat trunk |
Author: | j2dapo [ Tue Sep 24, 2013 6:29 pm ] |
Yeah I couldn't find one of those ggsx tanks here. PnP like to puncture the tanks on all the cars the have. I also didn't want the tank to hang too low at the back. I'm sure I'll hate running that 12 g cell but i like the way it fits from the back of the car. I'm going to run the vent line to the old gas filler door. I ran an8 fuel feed line to the engine bay. The an6 I'm using to plumb in the stock csm fuel feed line as a return. I'll have to look at your DVD again; I recall you relocated where the e brake cables mount in the cabin? The awd ones seem long. I also need to replace some wiring from a fire I had while welding in the first drive shaft mount. |
Author: | LILEVO [ Tue Sep 24, 2013 6:34 pm ] |
Shouldn't have to do anything w ebrake. I'm using 1g awd cables. |
Author: | j2dapo [ Mon Oct 07, 2013 12:59 pm ] |
No pics on this post. Went to PnP yesterday. Came home with a nice carpet out of a low Kms 92 sedan, plus some ebrake cable clamps. (why do ppl scarp such a clean shell??). I may go back and cut some rear panels off this car. Also saw a GGSX there, I looked at the tank and it was punctured 3 places, (a-holes). I'm not comfortable welding gas tanks. Anyhow I finished the ebrake cable and am almost done with the return fuel line. I will be welding the rear sway bar end line mounts next. I think I will set the car on its wheels to get the proper placement for these mounts. |
Author: | miragesist [ Mon Mar 24, 2014 4:50 am ] |
saludos amigo. acabo de venir de tu tierra. me cominun buen entrecut en el restaurant ELADIOS. buen trabajo. para cuando corre? |
Author: | Broke4speed [ Sat Apr 05, 2014 5:59 pm ] |
for Swede Density. |
Author: | j2dapo [ Mon Apr 20, 2015 10:11 am ] |
yearly update, car was on the road last summer and will be again this year. Notable items that needs attentions: Too loud, I added another resonator and a silencer. No rear toe adjustment, bolts where rusted in bushing and would not turn. removing those was fun. pics to come. Needs more tune. Less notable: Body panel repair picked up some sentra GC sleeves and springs, that fit the 1g dsm agx's. I'll try the rears first. engine mount bushings - I have the parts on a shelf. Evo 1 rims that need attention Fog light grill. ..., in a general sense - use the parts from the shelves or sell them. I wont get to most of these anytime soon. |
Author: | j2dapo [ Sun Jun 28, 2015 2:51 pm ] |
Quote: Shouldn't have to do anything w ebrake. I'm using 1g awd cables.
They do work. However the ebrake handle needs to be pulled much higher. I started the car again. changed the oil. ECU is now on the latest SwD (speed density) release. I also noted that there is coolant dripping from the timing side of the motor. Could this be the water pump? |
Author: | Flying Eagle [ Sun Jun 28, 2015 11:34 pm ] |
Weep hole is on the side, may be visible from the side of the cover. That is the only coolant related orifice on that side of the motor IIRC. |
Page 3 of 4 | All times are UTC-05:00 |
