It is currently Sat Apr 27, 2024 11:32 pm
PostPosted: Thu Oct 09, 2014 8:13 pm
Any suggestions or pointers from guys that have done it would be great..
PostPosted: Fri Oct 10, 2014 3:17 pm
There are plenty of picture filled build threads on this site, I'd start there.
PostPosted: Fri Oct 10, 2014 7:30 pm
the very first decision you need to make is... what rearend to run.. the 1g dsm or the ford 8.8... from there you can search for build threads to suit which one you plan to use and go from there..
each rear end mounts differently and uses a diff suspension setup..(or u can make your own mounts for that per which rear u go with)..
Users browsing this forum: No registered users and 53 guests
