It is currently Tue Jun 04, 2024 8:30 am
PostPosted: Fri Jul 31, 2009 1:19 am
ok i bought a tranny and transfer case for 50 bucks the only thing that is wrong with the tranny, it wont go into 5th gear,
can anyone give me an idea of whats going on before i open it up?
PostPosted: Fri Jul 31, 2009 1:35 am
what about reverse? if no then its either the roll pin holding the shift fork... or the fork itself is broken.
if its only 5th gear then the only thing I can think of is the syncro is so bad it wont let it go into gear.
PostPosted: Fri Jul 31, 2009 6:05 am
thats what iam thinking...
1st, 2nd, 3rd, 4th, and reverse are fine
PostPosted: Fri Jul 31, 2009 7:25 am
I think I remember reading something about one of the nuts backing off a bit causing it not to go into 5th. May want to check Tuners or somewhere where they deal with dsm's a bit more.
PostPosted: Fri Jul 31, 2009 8:45 pm
Remove wheel, pull of the end cover bolts, verify that the 32mm(?) nut is not falling off the shaft.
PostPosted: Thu Aug 27, 2009 11:55 am
i have pulled it off the cover both of the nuts are secure, but when i shift it into 5th, it goes into gear but the syncro pops off
i will take pic tonite and post them.
PostPosted: Fri Aug 28, 2009 1:26 am
this is how everything looked as i opened it up
inside cover
now i think its in reverse
under syncro
can anyone tell me if there is any parts missing or if something place incorrectly?
thanks
