Tubular rear lower control arms (AWD) http://4g61t.org/forum/viewtopic.php?f=57&t=27452 |
Author: | oil-burner [ Tue Dec 30, 2008 9:02 pm ] |
Post subject: | Tubular rear lower control arms (AWD) |
Since I couldn't find a good set of rear lower control arms for the AWD conversion in the mirage, I made my own. Made a sleeve that the factory ball joint will press into, then added the tube & threaded end. A heim end will make up the inner pivot point, so it will be adjustable. everything is chromoly, I was worried it would be heavier than the factory unit, but it's 1-lb lighter. Just need to finish the swaybar mount.. scot |
Author: | SpinMasta11 [ Tue Dec 30, 2008 10:45 pm ] |
Post subject: | Re: Tubular rear lower control arms (AWD) |
Wow. I've actually wondered if anyone had tried this before. I can't stand the stock lower control arm, its gay as hell. The stock cam bolt for that thing breaks the rim on the subframe, and the bolt/nut usually rusts all to hell too. What is your opinion on running no sway bar, say for a car running in straight lines usually? |
Author: | oil-burner [ Tue Dec 30, 2008 11:24 pm ] |
no rear sway bar for str-8 line stuff would be no problem.. scot |
Author: | Flying Eagle [ Wed Dec 31, 2008 8:23 am ] |
Note to self, Scot is really good at welding metal together. |
Author: | Evotistical [ Wed Dec 31, 2008 4:37 pm ] |
Quote: Note to self, Scot is really good at welding metal together.
dudes a robot, perfect c's in all the places I see.
Author: | 89Mirageman [ Wed Dec 31, 2008 4:46 pm ] |
If the rest of your swap has the same quality work I can't wait to see it. Great job! |
Author: | MattGSR [ Thu Jan 01, 2009 7:47 am ] |
scot, i sent you the corners....oh can you make these to replace the stock ones, freaking welding machine ! |
Author: | twokss [ Mon Jan 05, 2009 9:54 pm ] |
can i have some? |
Author: | Mechacode [ Mon Sep 07, 2009 1:00 pm ] |
Hey Scot, did you ever get these figured out? |
