humm, im a certified welder and own a miller-matic , I just need some guidance into wich direction to go. I know a tunnel will have to be fabed and thats not a problem. I have a whole 4-bolt setup in my basement with drive shaft. Shouls I try to use the factory 1g mounting locations for everything or what... Its just totally different under the hyundai and the 1g . Seems kinda like I would be pissin in the wind.
I have a 95 Hyundai Elantra, and the stock tunnel should be fine, it's deep enough for the drive shaft. So far from doing a lot of looking underneath my car, they are the same as a CSM, so if you follow through like a CSM, you should be all set. I also have a 93 hyundai excel with a 4g63t swap that I had for 3 years now and wished that I could make it AWD though. The wheel base on the excel is 53 inches and shy of another 3 inches. One day I measured a 94 hyundai elantra in the pick-a-parts, and measured the wheel base of it, amazingly that the wheels base was the same as a CSM, so that why I have a elantra now.
Doing AWD is every possible and quite a bit of fab work which need to be done inorder to to mate the DSM AWD rear end to the car. Possible? YES Alot of fab work? YES, Is it worth the swap? YES!!!!!
