I decided to go the crossmember route. I thought it would be a lot easier than the alternative. took 3 or 4 hours to make. I painted it right after i took the pictures of it, then installed it again.
All 4 motor mounts are now finished. Took me all day to do. It was a pain in the ass to get the motor positioned correctly since i had none of the turbo colt or elantra mounts to work with. I basically used the axles to position the motor left to right and i just kinda guessed the rest, making sure the driveshaft output was straight with the driveshaft.
And making sure the motor isn't up too high to clear the hood, that's why the hood is back on.
As you can see, it is 5 bolt. I used the driveshafts and spindles off the dsm. One great thing about doing it this way Is it is free. I am very excited that this worked out as good as it did. It is not tightly bolted together yet, as i will probably lower the front suspension slightly to aid the steering geometry, Using dsm spindles means you have to invert your tie rod ends, thereby causing them to be on a slight angle. I figure lowering the front end one inch should solve it, I would like them to be perfectly straight if possible. than i can set the camber (this setup messes it up a bit, lowering the car should help) and do a wheel alignment.
It's turning out to be not only easier but cheaper than i would have thought. When i started this project i always had planned on new colt turbo axles, and didn't know how i would get 5 bolt hubs on the front. I'm also happy that most of the rolling around on the floor crap is done with. Now i can move on to the fun stuff like bolting it back together.
Still sitting at 380 bucks.
