It is currently Tue Jun 04, 2024 4:50 pm
 Post subject: Tranny question
PostPosted: Thu Jan 24, 2008 6:52 pm
I own a 89 colt GT, and everyboy da owns a colt would like to make it AWD. well is not my goal yet but im looking to purchase a tranny from shepher. Could i used a AWD tranny now untill i decide to go AWD, i dont want to spend money on a FWD and them buy a AWD later on...... Thanks
 Post subject: Re: Tranny question
PostPosted: Thu Jan 24, 2008 6:55 pm
You can use an AWD tranny, but you'd have to weld the center diff or eliminate the viscous coupling by using a spool or something of that nature.
PostPosted: Thu Jan 24, 2008 8:53 pm
Ok, but can i used it when i do the AWD setup. How much more i have to spend to make work...
PostPosted: Fri Jan 25, 2008 12:56 am
If you weld the diff to run the AWD tranny in FWD mode, when you hook up the AWD stuff you'll have a locked diff and the car will drive as such. I really don't recommend doing it at all.
PostPosted: Fri Jan 25, 2008 4:47 am
If you are serious about going fast you will need to weld the diff. Driveability Is not that bad as long as you have power steering. My $0.02
If I had a dollar for every V8 beaten by a colt I would be a millionaire. But I would still be driving my colt.
