It is currently Sun Apr 28, 2024 8:14 am
PostPosted: Wed Aug 22, 2007 4:04 pm
I have a '92 Eclipse subframe for my AWD conversion(yes, I am still trying to get it done). This thing needs to be taken apart, resurfaced, and bushings replaced. I have a lead on a NEW '92 Gallant AWD subframe. Can I use this as well as the 1st gen Eclipse? Does anyone have a list of the rear subframes that can be readily used?
PostPosted: Wed Aug 22, 2007 8:27 pm
I will be using a 91 GVR4 rear subframe on my Elantra conversion. You just have to remove the 4WS components and put a 40mm freeze plug in the pumpkin where the pump was. It has the 4 x 114.3 rear hubs as well that match the CSM's bolt pattern. There is a pic of mine in my Elantra thread.
Where in the world did you locate a new one?
PostPosted: Thu Aug 23, 2007 11:41 am
90-94 1G subframes,
91-92 GVR4 subframes.
Replace ALL bushings while subframe is on the floor. Replace all rusted nuts and adjustment bolts too.
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Thu Aug 23, 2007 5:08 pm
:evil: Well, it depends on what people mean. Unfortunately, my man only meant the crossmember support bar, you know, that large, beefy, V shaped thing. I told him I wanted the whole works sans shocks and rotors. You know, trailing arms, upper and lower control arms, etc. "Oh [gosh]," says he. "That would be $1,000, or more." "Well, never mind (or words to that affect)", says I.
Thanks to Mr. Hyde. That is exactly what I am trying to do right now.
It is apart and in the process of clean-up. Any good handle on bushing suppliers?
PostPosted: Thu Aug 23, 2007 5:55 pm
www.jnztuning.com for polyurethane chassis and suspension bushings
Geoff
89 2.0 Turbo Colt
Users browsing this forum: No registered users and 59 guests
