It is currently Wed May 22, 2024 9:25 pm
Post new topic  Reply to topic  [ 108 posts ]  Go to page Previous 1 2 3 4 58 Next
PostPosted: Sat May 17, 2008 8:06 am
I found this 1" by 2" box tubing in the scrap metal pile at the steel place and thought it would work for a crossmember. It did.
PostPosted: Sat May 17, 2008 9:45 am
That's pretty good.
I took a look down there and it almost looked as if the sway bar was right in the middle of the "hole" in between the transfer case and firewall. I didn't think any sort of mount would make it through there.
I might make something like this if I get bored. My rear crossbar is on its second fail with the AC mounted. I need to re-do it again.
PostPosted: Sat May 17, 2008 11:51 am
Yeah if it wasn't for this thread, and the picture of the jdm piece, i wouldn't have considered doing it this way either. I can just barely wiggle it into place, who knows how strong the rear mount is too, given the 60 degree angle it's on. Now the crossmember has to be removed before the engine can be ( i think). But that's no big deal.
PostPosted: Sat May 17, 2008 12:48 pm
I have been planning on doing mine something like that for quite some time now. Looks good, and +1 for not going the same cookie-cutter route as everyone else.
PostPosted: Sun May 18, 2008 10:48 pm
Yeah supposedly the AWD CSMs from NZ and Australia had the crossmember similar to what you built but had a totally different sway bar and control arms that were used to make room for the rear mount. Let us know if it fits.
1999 Ford Contour SVT
PostPosted: Mon May 19, 2008 12:31 am
i would tell you guys if the swaybar is different between the FWD and 4WD models, but my cars so low now i cant even peak under the front anymore! :o
PostPosted: Mon May 19, 2008 4:00 pm
Of course it fits. I tacked it together under the car, then pulled it out and welded it solid, then painted it and put it back in. Keep in mind my install is possibly different than everyone else's. I made my own timing and tranny mounts too. My motor could be a little further forward (or backward) than everyone else's. But i doubt it cause the cv boots would be rubbing the body if it were 1/4 inch further back.
 Post subject: Re: Bolt up cross member
PostPosted: Fri Jan 09, 2009 12:51 pm
I just remade another one.Its wider and uses the tips off the factory crossmember.The one on my colt and like the one pictured above might cause vibrations.This one uses the factory bushings.I'll post pics of it to give you guys an idea.Mine has yeat to fail.
On a side note.Good stuff Pimpy.
PostPosted: Sun Jan 11, 2009 2:42 am
here are some pics of my bolt on cross member that miragetbo1997cc made for me.it is alot of labor involved. I was going to powder coat it but I am brook like everybody else. so I settled for the old getofabulos way a can of black priemer....maybe I will powder coat it later but it is not a priorety . I watched him make it. it is realy sturdy and fits perfectly. he also did all the welding work for my awd swap. so now I am almost ready to get back on the track.I still need a clutch and a fuelcell. see you soon.... :weedman:
PostPosted: Sun Jan 11, 2009 11:44 am
That is a simple, nice looking piece you have there. Miragetbo, what fabrication technique did you use to help jig that crossmember?
PostPosted: Sun Jan 11, 2009 1:46 pm
Climb under the car and goto town.I didnt jig it.
PostPosted: Sun Jan 11, 2009 2:29 pm
Build a jig and start producing!
PostPosted: Mon Jan 12, 2009 12:47 am
I'm not sure how that will bolt up on the car and why it looks that way though :-k or maybe I'm looking at it from a wrong angle or something, idk,lol. Let's see it bolt on hummm,lol. :pics:
PostPosted: Mon Jan 12, 2009 1:16 am
its basically a copy of a stock 4WD crossmember, well not a copy but follows the stock route
PostPosted: Mon Jan 12, 2009 1:30 am
this crossmember bolts up and will clear the transfer case no problem?
