It is currently Fri May 17, 2024 5:05 pm
 Post subject: 14b @ the strip
PostPosted: Sat May 15, 2004 9:54 pm
First time out with new mods. I was hoping to get in the 14's but it's going to take either more tuning, more boost, better driving, or bigger turbo: or maybe all that!
Anyway, did three runs with best of 15.361 @ 91.07 with 2.40 60'. At least I beat a '90 Accord with Prelude v-tech swap.
Any track experts feel free to diagnose.
edit:this was with '61t, smic, 450's, 60mm tb, maft, stock boost
PostPosted: Sun May 16, 2004 12:53 am
i dont think you want too many people to comment on it.
or not
PostPosted: Sun May 16, 2004 6:27 am
Well 2.40 60foot that can be brought down to a 2.0 how was the wheel spin? maybe som drag radials or full out slicks?
PostPosted: Sun May 16, 2004 10:28 am
And another thing with those slicks turn up that boost :twisted:, that should get u in to the 14's.
 Post subject: Re: 14b @ the strip
PostPosted: Sun May 16, 2004 11:22 am
turn up the boost.
I got 14b,sidemount,450s,maft and ran 14.0@97 at 3k elevation and my car has the tired 280k original engine
89 mirage 4g61t
PostPosted: Sun May 16, 2004 1:19 pm
Scratch the "bigger turbo" off that list until you get well into the 13's. (I've ran a 13.9 with a tiny T25.
Are you still running the stock exhaust? If so, get rid of that. Also, get a manual boost controller and set it to about 15psi, unless you can do some tuning.
PostPosted: Sun May 16, 2004 7:18 pm
Thanx for the input. Traction wasn't too bad as there was a lot of rubber on the track. I would sidestep the clutch at 3500 rev's and spin thru first but not enuf pwr to spin in 2nd unless I really abuse the clutch(and who would do that, j/k). I do have 2.5 mandrel downpipe and 2.5 pressbent catback. This week it will get a new mbc. I had a fish tank bleeder valve for the 11b, but I didn't like it so it got tossed.
BTW- Acording to a horsepower calculator my '61t is now making 184 @ the crank which is about 50 more than stock.
PostPosted: Sun May 16, 2004 7:33 pm
tuning is everything, what kind of device do you use to monitor the knock?
the 4g61t on a stock exhaust and a little t25 got me to 100 mph.
traction is my concern now.
PostPosted: Sun May 16, 2004 11:56 pm
Need to work on your launch, deff room for improvemnt on a 2.4 60ft, your not on stock 13" steelies are you? Don't know what you consider stock boost, if you have a fuel pump-walbro I would suggest kicking it up to 15-16psi. Proabbly just need soem more pratice, fwd can be a handful, may wish to consider some cheap wide rims and some Drag Radials for the track if making a best time is important.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
PostPosted: Sun May 23, 2004 12:46 pm
Dude you need to "baby" it off the line, DONT drop the clutch at 3500. I have the 63t/14b w/ 195/60R14's and have gotten a 2.1 60ft getting out of the hole gently and if I try to launchhard I never get better the a 2.4
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Tue May 25, 2004 2:01 pm
1595 cc's of fury
My 14.9 was on an 11b set to 13 psi. This was also at denver elevation and I was getting consistent 2.3's on crappy tires. Just turn up the boost and try to eliviate some wheel spin.
PostPosted: Wed Jun 30, 2004 11:31 am
more boost, try it up to 15psi, and keep your eye/ears on knock, or egt's.
DRCOLT
1989 3g Colt GT turbo w/4g63t
PostPosted: Tue Aug 10, 2004 12:44 am
Banned for being a dick
Are all running on 1.6L?
PostPosted: Tue Aug 10, 2004 8:02 am
Yep, if I go bigger the Honda guy's will whine unfair.
PostPosted: Tue Aug 10, 2004 9:02 am
I went 14.8 @ 100 with a 14b @ 15psi through a stock exhaust....... :oops: so dont feel bad :wink:
89 Colt GT, 4G63T, 60-1 @ 30 psi, NX wet 75 shot...
97 Jeep Wrangler
