It is currently Tue Apr 23, 2024 7:04 pm
PostPosted: Fri Apr 26, 2013 11:12 am
So we had our first test n tunes at Rocky mountain raceway on Wednesday so I thought it would be a perfect time to take the colt out and do some shakedown runs and set a nice solid baseline. I was very pleased with the results for the car only being on pump gas. First run ever off the trailer was a 12.12@115 1.8 60'. After this run I aired down the tires to 20psi (due to me spinning through first and part of second) and also turned up the boost. This was definitely a mistake. 28psi on pump is no good haha. Ran a 12.9 on the second run.
I turned the boost back down and was able to run a 12.23@113 1.8 60' after this they called it a night.
Overall I'm very pleased with it being my first time out with the car. Here is a mod list and the vid of my 12.12 run.
89 colt gt awd swapped
Stock bottom end 1990 4g63
Dsmlink v2
Hks 272s
Fic 1050s
Holset hx35 bolt on
Act 2600
4 bolt rear
Gcc w/ konis
225/50/15 bfg g force sports
http://m.youtube.com/#/watch?v=j3Urba_C ... 3Urba_CMNU
89 Original Turbo Colt Gt AWD PTE 6262 Built 9:1, TRE stage 2. 10.93@129
05 Evolution VIII FP Green, garage queen.
97 Eclipse Gsx 80k miles, 6 Bolt, HX-35
08 Ford F-350 6.4 PSD 3 mods and 600hp :)
PostPosted: Fri Apr 26, 2013 1:15 pm
that video is of a 13.9 pass...but grats on the 12.12 and 12.23 passes
PostPosted: Fri Apr 26, 2013 1:33 pm
Thanks for catching that! This.should be the right one.
http://www.youtube.com/watch?v=NMX0yWvQ ... ata_player
PostPosted: Fri Apr 26, 2013 5:06 pm
very nice.. had to watch it a few times.. kept missing the start looking at that girl LOL...
PostPosted: Fri Apr 26, 2013 6:57 pm
Nice job reeling in that Camaro! Car sounds mean.
PostPosted: Sat Apr 27, 2013 10:50 pm
Thanks man ^
Took the car to the track again today. It was much hotter and the track was much stickier. I ran back to back 12.1s @114. Two 1.7 60's and one 1.6.(missed 3rd though). I am pretty positive this is all I can get out of it on pump. 11.3 afr, 12 degrees peak timing and 24psi. Overall I am very happy to know my awd swap is solid and the car is this fast on pump!
In car vids coming soon.
PostPosted: Sun Apr 28, 2013 1:49 am
Thanks man ^
If you're not knocking, and you still have room to go on your injector duty cycles, I'd say run more timing or run a bit more boost, or both.
PostPosted: Wed May 01, 2013 6:48 am
Damn nice! My butt hole was puckering when you came back on that Camaro, gives me motivation to get back to the track, well done!
