It is currently Fri Apr 26, 2024 11:55 pm
PostPosted: Fri Dec 30, 2011 2:40 am
Street is a closed street, van is my friend flowing nd car uptop is a friend taking a video..
http://video.ak.fbcdn.net/cfs-ak-snc4/3 ... da339952db
Car is on e85, not sure on the boost was not logging but boost was turned down from 25psi.. Launch was decent let off nd hit it again to catch traction.. 2nd nd 3rd went in fine put it into 4th uptop for a bit nd let off due to a slight turn nd dead end coming up .. A/f on the rich side of 11.3-11.4 timing is about 19-20 * uptop, i feel that timimg is to much..
Mods
2.0 Wesico 8.3.1 compression
Stock rods
Stock head
Fp2 cams
Arp head studs
Feltpro prematora hg
Tre stage 2 trans with welded center dif
Act 2600
Ecmlink v3 sd setup
Jmf smim
Ets fmic race core
Sb racing mani
Tial bov nd 38 mm wastegate
Frank level 3 turbo 20g
All supporttimg mods for e85 fp at 45lb
Basic mods
Car has a small vaccumm leak at the tb from shaft seals
Overall car ran decent, not fully impressed with it but still getting it all twicked up nd on point..
PostPosted: Fri Dec 30, 2011 10:48 am
Looks and sounds pretty fast! Nice work.
PostPosted: Fri Dec 30, 2011 12:18 pm
Yeah, last night passes, i wasent really impressed, i know the car has more in it, im going to bring the car to my friends shop look everything over, log the car set the boost higher, and hopefully have the gopro on the car.. New videos should be up in the next few days
