It is currently Wed May 08, 2024 1:58 am
 Post subject: 12.1 @ 113
PostPosted: Thu Sep 03, 2009 12:26 am
Two in-car videos of my runs.
http://lilevo.com/lilevo2/gld2009/run.wmv
http://lilevo.com/lilevo2/gld2009/run2.wmv
My best was only a 12.1 @ 113 with a 1.77 60' (no timing pulled). I ran two 12.3's at 114 and 117 with timing being pulled due to knock. My car is missing some serious power/top end somewhere. I was going faster without the Magnus SMIM and a stock, rod-knocking motor last fall.
This is a 35R, 22-25psi, Magnus SMIM, built motor, 272s, etc.
 Post subject: Re: 12.1 @ 113
PostPosted: Thu Sep 03, 2009 12:42 am
Windows media player says there is a problem with the server....guess I will check back tomorrow
Good stuff - trucks bring it!
PostPosted: Thu Sep 03, 2009 12:54 am
Don't stream the videos, download them to your computer...
PostPosted: Thu Sep 03, 2009 12:57 pm
Something is WAY wrong..
I was trapping low 120s on stock engine/intake. 35r, 280s and 23psi on a chipped ECU
What are you tuning with? and whats your timing at WOT
PostPosted: Thu Sep 03, 2009 1:29 pm
1595 cc's of fury
Something odd happening up top, it really seems to be losing power on the big end.
I'm sure you'll get it figured out and report back with better times. :rock:
PostPosted: Thu Sep 03, 2009 2:31 pm
Hi Jason,
You also have to consider that a 35r likes boost. It will be awake at 30 and fully awake at 35.
Regardless, there it something wrong.
My trim 50 with stock cams and 30psi with a full weight car is pushing me to 128 mph.
You seem to have a good transmission that shifts well. 12.1 for 113mph means good traction and good shifting!
Can you prvide us with a DSMlink log?
PostPosted: Thu Sep 03, 2009 3:23 pm
AEM EMS.
This is the calibration I used during my first 2 runs. Timing map looks "normal", but you will see the areas of knock voltage spikes. (12.3@117, 12.3@113)
http://lilevo.com/lilevo2/gld2009/logs/ ... .V1.19.cal
Here are the logs of the first two runs
http://lilevo.com/lilevo2/gld2009/logs/12_3_117_ext.stf
http://lilevo.com/lilevo2/gld2009/logs/12_3_117_int.stf
http://lilevo.com/lilevo2/gld2009/logs/12_3_113.stf
This is my modified third run (12.1@113) calibration. I just pulled timing back over 7000RPM to get rid of the retard since I figured it was real knock.
Here is the log of that run
http://lilevo.com/lilevo2/gld2009/logs/12_1_113.stf
PostPosted: Thu Sep 10, 2009 1:07 am
Went back today after some ignition timing tweaking. Still dealing with some knock volt issues and timing retard. Still not where it should be.
11.6@120
http://www.lilevo.com/lilevo2/gld2009/9 ... 120mph.wmv
http://www.lilevo.com/lilevo2/gld2009/9 ... 118mph.wmv
http://www.lilevo.com/lilevo2/gld2009/9 ... _93mph.wmv
http://www.lilevo.com/lilevo2/gld2009/9 ... launch.wmv
PostPosted: Thu Sep 10, 2009 9:53 am
Nice. 120mph on pump gas is nothing to shake a stick at. Run like 28psi and like 2 degrees of timing and see what happens. 8)
PostPosted: Thu Sep 10, 2009 8:49 pm
What was your 8th time and trap on the 11.6@120?
Are you running meth or just straight pump? I'd throw in some of the good stuff, may shed some light.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Sep 10, 2009 9:52 pm
60 1.76
330 4.87
1/8 7.45
mph 96.20
1000 9.70
1/4 11.61
mph 118.93
60 1.74
330 4.96
1/8 7.53
mph 96.8
1000 9.74
1/4 11.62
mph 120.6
93 octane
PostPosted: Thu Sep 10, 2009 10:20 pm
We'd be dead even. :drinkers:
Any chance you are knocking a shit ton? Seems like it by all the times and speeds - makes less and less power under more load. I'd throw in some octane strictly for debug purposes and see what happens.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Sep 10, 2009 10:21 pm
..and you need another car. God knows I do haha
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Sep 10, 2009 10:32 pm
It is picking up knock. If you know anything about AEM EMS and the logs you can take a look at them
http://www.lilevo.com/lilevo2/gld2009/9_9/
STF file is the datalog.
It's pulling back 3-5 degrees of timing in a few spots in 2nd gear, all through the top of third gear, and two spots in 4th gear. (I'm at 13 degrees all through the power band at 22-24psi)
PostPosted: Thu Sep 10, 2009 10:49 pm
throw some c16 in the tank (even half and half) just to try to eliminate the knock. yes, it will slow down through the traps due to retarded timing, but adding some timing and pulling fuel will net you another 5 or 6 mph i would imagine with race/pump mix
