It is currently Thu Apr 18, 2024 8:47 pm
PostPosted: Sun Jun 10, 2007 10:02 pm
I've always wondered how would fit 24.5's on my car....I could not find the answers elsewhere so I decided to buy some and see.
I am using these Draglites Weld Wheels with 5.5 inches of backspacing.
On the following pictures, the slicks where mounted so the surface of the wheel is sitting on the stupid hub protruding bolt heads. so i will use a .250 spacer to clear them wich is about the thikness of those bolt heads
I am going with coil overs anyways, but those pics shows how they fit with the oem struts.
PostPosted: Sun Jun 10, 2007 10:04 pm
oups.... moderators, please move this into racing discussion.
Thanks!
PostPosted: Sun Jun 10, 2007 11:07 pm
I would have went to a 4" or 4.5" backspace, I can defaintly see these rubing when aired down and when they expand.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
"Just like in the old days-More Horse Power means more crap to pick up-lol"
PostPosted: Mon Jun 11, 2007 8:21 am
Yep, they will balloon down the center won't they? Maybe space them out 4" to the outside, like the guy from CT. :D Nice wheel and tire choice though, but coilovers would certainly aleviate the perch spacing issue.
PostPosted: Mon Jun 11, 2007 4:28 pm
I know that! :twisted:
PostPosted: Tue Jun 12, 2007 12:04 am
.... sick puppy! :P Looks great, stop goating us and get some videos of those slicks flying down the track. :butthead: :lol:
PostPosted: Tue Jun 12, 2007 7:04 am
Ok, one more, just to bug you!
PostPosted: Tue Jun 12, 2007 7:35 am
Updated your link!
http://store.summitracing.com/egnsearch ... d%20Wheels
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Sat Jun 16, 2007 3:11 am
I had those exact same M/T slicks. They were 15's on steel rims. They did not clear the strut on the stock suspension. They did while cruising and sitting(still had to grind them down). Under load at the track or wide open throttle they would just stand up way too tall. Mine stood up a full two inches.
Steven
1985 Mitsubishi Cordia
Build in progress
PostPosted: Thu Jun 21, 2007 8:01 pm
Coltmax,
Any updates on fitment with the GC's? Photos would be nice. What width tires did you go with?
PostPosted: Tue Jul 10, 2007 12:30 pm
This is what it gives
I had to use 5mm thick wheel spacers in order to clear the brakes and i also had to grind a bit the mag where our stupid bearing hub bolts are protruding.
Results:
1.912 60' on a very slippery track and 7.695 @ 107.73 mph on the 1/8.
My main problem for traction now, are the rear shocks (gr2)... they are bouncing due to the spring rate (250lb) and traction goes on anf off.
But the slick feel good. Rake angle is very limited though and stepping too hard on the brakes will make the fender touch the slick. I will order 7 inches spring for the front instead of 6 inches.
