It is currently Thu Apr 25, 2024 10:52 am
 Post subject: Times
PostPosted: Mon May 01, 2006 10:33 pm
1595 cc's of fury
So as stated in another post, my clutch is slipping but I still had plans to take it to the Street Machine Showdown. I turned the boost down hoping to reduce the slipping and ran 205/45-16 street tires @ 25 psi. The first two runs I tried pedaling the car to prevent slipping and boost was around 18 psi.
1st run
13.714 @ 115.81 -- 2.595 60'
2nd run
13.368 @ 114.95 -- 2.464 60'
The 3rd run I decided to turn boost up to 20 psi and keep my foot to the floor.
13.203 @ 118.77 -- 2.387 60'
When I shifted into 4th, the rpms went to 7,400 and I just kept my foot in it till I finished...mmmmm smell the clutch.
PostPosted: Tue May 02, 2006 12:14 am
:hail: :hail: :hail: :hail: :supz: Not bad for having a shitty clutch...The Car looked and sounded mean except when you hit 4th....
Str8fuct......
PostPosted: Tue May 02, 2006 2:49 am
Nice trap speeds, i bet you could knock half a sec off with a good clutch. So when was the clutch slipping, just in 4th gear? or when it hits a certain rpm?
PostPosted: Wed May 03, 2006 10:34 pm
1595 cc's of fury
Hard to say really, 1st and 2nd just spun the tires. Third would spin till about 70 ish, then the clutch would slip slightly. In fourth, the rpms would immediatly go to 7,400 and sit there until I let off the throttle.
