It is currently Fri Apr 19, 2024 10:57 pm
PostPosted: Sun Sep 11, 2005 3:58 pm
Vendor
60 foot time
suspension setup (struts? springs with rate? wheelie bars? other?)
slick size
approx whp
weight
track conditions
transmission setup (lsd, welded diff, etc)
etc
PostPosted: Sun Sep 11, 2005 6:34 pm
1595 cc's of fury
2.10 60'
1G AWD springs and struts (front coils cut)
Pepboy special 175/65/14's @ 20 psi
133.5 hp (uncorrected)
2300# w/driver
Good
Stock km210, factory clutch
I pulled high 2.1's and low 2.2's consistently on the stock 11B.
PostPosted: Sun Sep 11, 2005 11:53 pm
60 foot time: 1.877
suspension setup:KYB gas filled w/progressives springs
slick size: 195/60/15 Road tyre(Yokohama s306)
approx whp: 240 on old turbo
weight:1125kg/2480lb
track conditions: Dry, unprepped
transmission setup: viscous front lsd, open rear
PostPosted: Tue Oct 25, 2005 8:42 pm
1.3
not my car, but possible in fwd with boost by speed
Eddie Rosado
PostPosted: Wed Oct 26, 2005 1:47 pm
Whoa. Loan me $500?
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Thu Oct 27, 2005 9:44 am
1.92 60ft
22x8x15 mt/et streets
stock replacement clutch
kyb agx's for a awd dsm
315 whp 335 wtrq.
average++ track conditions.
and the transmission sucked ass. would shift to 2nd to save its life.
PostPosted: Thu Oct 27, 2005 11:37 am
Vendor
1.88 60ft
stock suspension, preped track, 23.5" x 8.5" x 15" m&h slicks at 16psi
first and only run for the car until it broke, my first launch in a fwd'er on slicks
car weighed approx 2100lbs without me in it
approx 250-275 whp
PostPosted: Fri Jan 13, 2006 4:42 pm
Banned for being a dick
16psi is a lot for slicks
PostPosted: Fri Jan 13, 2006 4:45 pm
60 foot time: 1.877
Updated:
60 foot time: 1.721
suspension setup:Tokico w/280lb rear springs, fixed rate.
transmission setup: viscous front lsd, mech lsd rear
PostPosted: Tue Mar 28, 2006 2:26 am
Whoa. Loan me $500?
u can get an avc-r for cheaper then that.
Eduardo
Eddie Rosado
PostPosted: Mon Apr 03, 2006 8:50 pm
constant 1.7 60ft
Stock suspension
225/45/17
400+awhp
92 awd tsi.
PostPosted: Wed Apr 05, 2006 11:02 pm
1.74 60 ft- that pass I went 10.8@136
Coil over kit from a neon, on stock front shocks, and 3000gt vr-4 rear shocks.- Rear=stiff.
23.5x8x14 Mickey T's on steelies (small contact patch)-12 psi
498whp 425ft lbs
weight-2200lbs.
Phantom grip insert
FWD turbo trans
Dry-Preped track
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Sun Mar 18, 2007 5:20 am
1.66 60 ft for once and I missed 3rd and 4th gear:)
constent 1.7X
d2 coilovers for 93-96 Mitsubishi Colt GTI hutchback from MY and my friend gets 1.7x in his Mitsubishi Colt Gti with JDM used evo 1-3 coilovers from junck yard but I do have so many bars in my car.
front and rear sway bars, front and rear anti rod bar, rear tie bar, two extra bars which I don't know what the name of them all of them brand named as UR, I even has polyrathane master kit I have 513 wheel hp with fp3065 my best time for now 11.1@213 km/h with 1.7x 60ft
I have 13*8*24.5 M/T slicks with 15*4.5*26 skiness both are M/T with weld rims I have so much bad traction:(
Now I'll move to M/H race master 13*8.7*25 slicks and hope to get conestent 1.6x, I can't use wheeli bar since it's not allowed in my group.
Anyone can help me to get more traction in my Colt GTI?
I'm a member in www.dsmtuners.com as alqatan and member in dsmlink forum as roadbeast79
Both my 2g Eclipse and my Colt has the same setup but with differnt turbo the Colt has fp3065 and the Eclipse has fp3575
I want to break into 10 sec but I can't:(
Can anyone help me please with better size slicks?
I run the d2 in very stiff at the rear and very soft in the front is it correct way to launch FWD, I have chaises of ca5a hutchback and body kit of Proton Satria GTI 98-2002 year model in my 93 Colt
I'm the best when you put to the test!
PostPosted: Tue Mar 20, 2007 5:43 pm
60 foot time: 1.877
Updated:
60 foot time: 1.721
:oops: I was about to shoot myself for not being able to lower my 60's below 2.3 with the street tires..... until i realized what that meant
mech lsd rear
 Post subject: best slicks
PostPosted: Fri Mar 30, 2007 11:51 am
whats the best slick to use for a 15" rim. how wide of a tire can these csms fit on them. I also have 90 fwd kyb gr2 gas shocks with lowering springs im not sure wat kind of springs, but can i use these springs or shocks on my csm i know i cant use the shock in the front since the csm has 2 bolts and the dsm has 3 bolts for the shock. Im just looking for the best gripping tire. Any suggestions?
IF Nismo means Nissan Motorsports wouldn't Homo mean Honda Motorsports??
Users browsing this forum: No registered users and 23 guests
