It is currently Tue May 21, 2024 4:30 pm
PostPosted: Tue Apr 05, 2005 10:53 am
I'm not sure how many of you have used the G-Tech before, I've heard both sides of the story. We've had relatively close results with the ET's, but the mph seems to be elevated a few MPH from track times which is what the G-Tech instructions will tell you.
Anyway, on the stock 155/80/13's burning them thru 1st, 2nd, and part of 3rd I ran 14.40@111. I tried again launching in 2nd gear at a low RPM and it took awhile to reach boost and still ran a 14.27@112. Those times seem pretty comparable to what most are running with the swap. I think it's easily capable of 13.90's with some decent drag radials or slicks.
This is with a stock 4G63T swap and a small front mount. I can't wait to do some mods and hit the track with some slicks.
PostPosted: Tue Apr 05, 2005 9:00 pm
Nice times for stock; but 155/80's? I'd be embarrassed to be seen on those :o
PostPosted: Tue Apr 05, 2005 9:13 pm
That mph is probably way off, I bet you trap close to 105 with your setup.
1999 Ford Contour SVT
PostPosted: Thu Apr 07, 2005 9:52 pm
Dude, you drive a Dodge Colt (Mirage,etc) and you'd be embarrassed because of the 13's? That's hilarious. I just got the car and I'm CHEAP, and the car isn't in very good shape. I had planned on using my buddies drag radials until I found out that the Colt has a 4 x 114 bolt pattern so his Honduh rims wouldn't fit. I'll get some cheap steelies off of something.
PostPosted: Thu Apr 07, 2005 10:13 pm
well , no-one might take you seriously with the skinniest tires out there, but at least you got the sleeper look down 8)
check the junkyard for Tiburon rims, thats what i have.
PostPosted: Fri Apr 08, 2005 10:13 am
if i owned a colt i would leave the stock rims on it even after a 4g63 swap
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Fri Apr 08, 2005 3:56 pm
Yes they will, your just not thinking of the right Honda. Think 4 doors... Mint Alloy 6 bar wheels that can be had in a junkyard.....and for cheap....
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Fri Apr 08, 2005 3:57 pm
Current
08 535ix 420awhp
PostPosted: Fri Apr 08, 2005 3:58 pm
Yes they will, your just thinking of the wrong hunda
Current
08 535ix 420awhp
PostPosted: Fri Apr 08, 2005 5:13 pm
You mean my buddy has the wrong car? His drag radials fit just fine on his Civic Hatch. Maybe he should get an Accord or Prelude so he'll mount his drag radials on some rims that will fit the Colt. Yep, I'll convince him to trade his 11 second hatch on an Accord just so I can borrow his wheels because I'm too cheap to buy my own, right now. Just kidding. I'll get some rims. I just can't decide if I want to buy drag radials or slicks.
PostPosted: Mon Apr 18, 2005 3:35 pm
Slicks if you're only using them at the track, drag radials if you plan on putting them on the car, driving to the track, running, driving home. Slicks are best for traction though.
