It is currently Wed Jun 05, 2024 5:16 pm
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu Oct 15, 2009 11:55 am
I'm not sure if you've already posted it, but what's your setup? What turbo, mods, etc. ? That is really, really impressive.
PostPosted: Thu Oct 15, 2009 12:47 pm
Your car damn sexy.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Oct 15, 2009 1:40 pm
Did you go seen pics on the link I post? With that you'll have an idea what the car look and have.
But in general:
6 bolts bloc and 7 bolt head
2g pistons over .02'' on 1g big rod
fidanza flywheel
act2600 with 6 pucks sprung
stock tranny 1g awd with weld center diff and everything rebuilt by me
Fp3065 full turbo setup with FPrace manifold, tial 44mm etc etc
DSS costum aluminium drive shaft 3''
4 bolts rear diff lsd
ksport coilover costum
Fic 1600cc injectors
Everything in braided front to back in -8AN
double walbro pump inline 255lph
Jaz 12 gallons fuel cell
stock cam
stock intake
stock head
63mm NT TB ported to 67mm with a little porting to the intake
etc etc etc
Overall its look like that! But like I said if you go see on my link that I posted on monchar.com you'll see all my mods et alot of pics of the car.
colt 200gt 3g swapped awd
9.92@143.1mph
1.43 sec best 60'
PostPosted: Thu Oct 15, 2009 1:50 pm
Stock cams? Seriously? :o
PostPosted: Thu Oct 15, 2009 2:08 pm
Yes! :) That why I say next just with somes fp2 cams, head porting, nlts and a little bit of practice again with the car at the track 9sec will be there for sure :supz:
9.92@143.1mph
1.43 sec best 60'
PostPosted: Thu Oct 15, 2009 2:13 pm
That's really unbelievable. What do you use for engine management?
PostPosted: Thu Oct 15, 2009 5:53 pm
this is his setup for 2009:
Setup 2009:
10.15@138.5 mph Best mph et best ET a vie
The fastest and quickest 3g colt in the world :D
Moteur:
-Bloc 6 bolt 2.0l 4g63t percé over 0.5mm
-Pistons 2g sur big rod 1g
-Crank, rod, piston balancé
-Studs ARP
-Valve cover avec fitings -10 et -12AN avec catch can Moroso
-Radiateur Scirroco en aluminium
-2 slim fan Mishimoto 12''. Une puller et une pusher
-Lifters 3g
Admission d'air/exhaust:
-Manifold FP race avec ceramic coating chromé
-Wastegate Tial 44mm V-band
-Turbo FP 3065 ball bearing ( anti surge model)
-O2 housing Costum FP en SS 2.5po
-O2 dump tube externe FP
-Intake pipe aluminium FP 4po
-Hoses braidées prestone pour turbo
-Hose braidées Huile FP pour turbo
-Filtre à l'huile inline FP pour turbo
-Exhaust mendrel band 3.5po straith
-Fmic 32x12x3 outlet 3po
-Piping fmic aluminium 3po
-Maf gm 3po
-MafT 2g
-Throttle body 1g NT porté 70mm
-Intake manifold 1g porté pour throttle body 70mm
Drivetrain/suspension:
-swap awd( Serge Turcotte)
-Subframe arrière talon tsi 1g rebuilt
-Différentiel arrière 4 bolts
-Bolts, braquettes, bearings de roue etc tout en neuf
-Bushing kit prothane complet
-Planché avec tunel et support de drive shaft Costum
-Drive shaft costum 3po aluminium DSS
-Knocle avant talon tsi 1g( 5 bolts patern)
-Supports à moteurs pour awd avant et arrière costum( Élimination crossmember)
-Transmission 1g awd rebuilt clairences 3 millièmes
-Center différentiel soudé ( 50-50 )
-T-case 1g reserré
-Shocks towers arrière redressi
-Ksport coilovers full ajustable
-Clutch kit ACT 2900
-Flywheel Fidanza aluminium 8lbs
-Master de clutch de talon 1g
Fuel/ Management électronique:
-Injecteurs FIC 1600cc
-Fuel pressure régulator Aéromotive
-Fuel cell RCI 12 gallons
-Pompes à gaz bosch 044 inline et walbro 255lph inline
-Filtre à gaz Earl 10 microns
-Arrivé hose braidées -8an complet
-Fpr aéromotive
-Laptop IBM thinkpad T23
-Ecu eprom
-Dsmlink V2.5
Brakes/Roues:
-Disques ventilés aux 4 roues
-Pads PBR céramic aux 4 roues
-Calipers de bib brake 1g aux 4 roues
-Hoses à brake braidées aux 4 roues
-Mags 16x6.5 talon 1g late flat black
-Pneus 225/55r16 Potenza Re-01R
Intérieur:
-Bancs Sparco sprint bleu
-Panneau électrique pour switch
-Intérieur arrière stripé
-Boost gauge
-Tachomètre 4po
-Colone de direction ajustable colt turbo
-Volant de course Bride
-Quick release momo
Extérieur:
-Hood pins sparco bleu
-Plaques pour hood pins en carbon
-Bumper costum
-Peinture devant complet costum avec stripe flat black
-Headlight bmw E36
-Lumière au xenon 6000k
PostPosted: Thu Oct 15, 2009 7:02 pm
Well Dan, you really got the Captn curious! :lol:
PostPosted: Thu Oct 15, 2009 11:23 pm
I use dsmlink v2.5 and wideband aem.
Want you put the right thing at the right place and everything work perfectly it do that.
9.92@143.1mph
1.43 sec best 60'
PostPosted: Thu Oct 15, 2009 11:29 pm
Yes I saw hehe! I like to show at everyone as you don't absolutly need things like smim, big TB aftermarket who doing bad idle, big cams etc.... to do good times and something fast.
Setup 2009:
Moteur:
-Studs ARP
-Lifters 3g
-Maf gm 3po
-MafT 2g
-T-case 1g reserré
-Fpr aéromotive
-Ecu eprom
-Dsmlink V2.5
Brakes/Roues:
Intérieur:
-Boost gauge
-Tachomètre 4po
-Quick release momo
Extérieur:
-Bumper costum
-Headlight bmw E36
Yes! You put the aem wideband in that and somes other littles things and overall it looks like that.
And btw sorry for the french/anglish setup its becaus I'am a french guy from QUEBEC hehe.
9.92@143.1mph
1.43 sec best 60'
PostPosted: Fri Oct 16, 2009 10:36 am
Its weird hein!? When one of your friend guy made a good time like the black widow 10,74( its impressive ) everone answer in his thread and that done like 20 pages and now I beat the world quickest 3g street colt with 10.15 but just 3 or 4 guys come talk with me or say me congrats.
Is it becaus you don't know me or? Anyway, maybe its me....I just want to speak with you of that becaus I'am happy of made this time.
9.92@143.1mph
1.43 sec best 60'
PostPosted: Fri Oct 16, 2009 11:11 am
HAhahaha give it some time man.
As of right now i know what my next turbo is going to be. :D
I'll be completely honest though i find it pretty crazy you're almost trapping 140mph on stock cams.
I'm not saying i don't believe you but let's see what a set of better cams will do for you.
I think with no doubt you should be able to run a 9 second pass in the near future.
PostPosted: Fri Oct 16, 2009 12:13 pm
i guess you are the fastest now. but before you cataplt went 10.2 @140 mph and gsxtreme has gone 10.2 @137mph. cataplt sold his car but gsxtreme should be in the 9's anytime now. i cant wait to get my awd swap done over the winter, ill be right there with you guys. with the setup i have it should be no problem, just hope i dont break anything.
PostPosted: Fri Oct 16, 2009 12:34 pm
Hehe yes I know its just to see your reaction after I wrote that!
Btw coltmax know me very well so I can confirm you all my setup for those people who don't believe me for what I have.
And you'll very impressive by this turbo, its a very nice choice! Best turbo I ever had and from far.
9.92@143.1mph
1.43 sec best 60'
PostPosted: Fri Oct 16, 2009 12:44 pm
I know cataplt but like you said the car is sold so that does'nt count but I don't know gsxtreme. He is on the board here? Do you know where I can find a vid of his car I would like to see what look like.
But the day I made my 10.15@138.5mph it was only the first time I been at the track with the slicks and the second time with the car since he is awd and before that I never drove any awd car. And he left me place and somes power to reach with fine tuning becaus the setup is not at his full potentiel. i'am really sure just like the car was this day with other pass and practice it was 9sec. But this winter I'll change the oil rings, a little head porting and fp2 cams and in april go see what I'll be able to make with the car. After that I'll to do a 8 point roll cage and do my liscenc for 9.99.
You'll see, awd its just amazing! Its the better move or mods I done to date!
9.92@143.1mph
1.43 sec best 60'
