It is currently Tue Jun 04, 2024 8:33 am
PostPosted: Tue Aug 02, 2005 11:11 am
'89 Colt with 4G63T swap, FMIC, custom sheet metal intake, everything else stock. 175/80/13's cheapo tires.
I G-Tech'd it before and got a 14.27 @ 112 or something with 11psi.
First Pass went to do a psuedo burnout and knocked the #1 injector plug off. (I didn't put the cute little clips on) So, no boost and 3 cylinders.
60' 2.987
330' 8.057
660' 12.121
MPH 61.11
1000' 15.656
1/4 18.599
MPH 76.83
Second pass, Wheelhop out of the hole, broke the rear bolt that goes thru the motor mount, engine tilted back and landed the sheetmetal intake on the clutch master cylinder crushing it and knocking the resevoir off the master cylinder, clutch didn't work too good into 2nd or 3rd, then I powershifted 4th and knocked the injector plug off again, and the Manual boost controller exploded. NICE!!!!!!
60' 2.604
330' 6.698
660' 9.871
MPH 78.89
1000' 12.876
1/4 15.658
MPH 75.85
I had to drive home an hour with an electrical taped intake, and no clutch. Talk about fun.
The worst part is, my buddy in his NEON has been talkin' trash about the Colt saying that it feels about as fast as his 15.58 NEON. And I ran that. It sucked. I just wanted one "good" pass to get a timeslip. I was hoping for a 13.90. Oh well.
Hopefully, my next trip will be better.
PostPosted: Tue Aug 02, 2005 12:27 pm
:o JEBUS CHRISTO!!! lol! dood, get your car in good working order and make sure you secure everything next time! who knows what else is loose in there... i hope you don't end up like that 1g at last year's shootout...
PostPosted: Tue Aug 02, 2005 12:38 pm
Congrats, one of the worst passes down the track I have ever read about.
1999 Ford Contour SVT
PostPosted: Wed Aug 03, 2005 8:26 am
If something happens, it'll happen at the track.
Earlier that day, I replaced the front motor mount bolt because it had broken.
I just installed a stroker motor, since the 2.0L started knocking. I've got the gas tank out to switch fuel pumps and am deciding what to do about all of the broken fuel lines that I created. Hopefully I'll have it done and half-@$$ tuned by the shootout. I've still got a worn out 14B on it for now, so it won't be too impressive.
PostPosted: Wed Aug 03, 2005 1:28 pm
It doesn't sound like it will even make it to the shootout.
PostPosted: Thu Aug 04, 2005 11:03 am
heh that thing made my buddy jump and run for cover!
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Sun Aug 07, 2005 2:04 pm
Negative Nancy
when and where is this race coming up you guys are talking about?
PostPosted: Sun Aug 07, 2005 9:54 pm
Its in Ohio, Aug 12-14th.
PostPosted: Mon Aug 08, 2005 1:56 am
BANNED FOR FRAUD
Jason Veraldi
Scammer
PostPosted: Tue Aug 09, 2005 11:41 am
Wow, that was funny man.
Hey, ewere are you at in Ohio? It looks liek I am not the only one here now thats nutty!
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Mon Aug 15, 2005 12:22 pm
I'm in Bucyrus, it's sorta by Marion or Mansfield. If that gives you a better idea of the location.
I just installed the stroker motor I built for the AWD Talon in the Colt. It'll be fun once it's tuned. I need to log and tune and figure out why it's cutting out at 5 grand. The O2 is reading rich at about 1.05 volts, so I'll just have to log and see what the injector pulse width is to give me a better idea of what's going on.
PostPosted: Mon Aug 15, 2005 12:44 pm
Cool maybe we can meet up some time when you get it figured out.
Current
08 535ix 420awhp
