http://4g61t.org/forum/
Built Turbo 4G67 Dyno Numbers 422whp/382tq
http://4g61t.org/forum/viewtopic.php?f=42&t=40778
Page 1 of 1
Author:  Moulin13 [ Sun Sep 11, 2016 3:21 pm ]
Post subject:  Built Turbo 4G67 Dyno Numbers 422whp/382tq
There you go guys after almost 10k miles of abuse the 4G67t still running like a champ, I did a couple of upgrades 5756 Turbo and 1200cc Injectors, no the Ebay GSP td05h 20g didnt blow this time, I replaced it since it was kinda maxed out, I'm shooting for 450whp so I'm almost there...
https://youtu.be/FiU6kYP86C8
Author:  CaptainTonus [ Sun Sep 11, 2016 8:56 pm ]
Post subject:  Re: Built Turbo 4G67 Dyno Numbers 422whp/382tq
Nice work!
Author:  wrx110487 [ Mon Sep 12, 2016 2:25 pm ]
Good numbers... What are you revving that combo to? And remind me what exactly a 4G67 is from again?
Author:  xxNocturnalxx [ Mon Sep 12, 2016 3:11 pm ]
4g67 = 1.8 liter likely form a 92-95 Elantra
Great work and nice kill videos! :twisted:
Author:  Moulin13 [ Tue Sep 13, 2016 10:14 am ]
Thanks guys!
Yeah this 4g67 came from a 95' Elantra (last year), I'm just revving it until 7 or 7.5k depending on the gear, my transmission is pretty much the one that limits me there especially since I'm using nlts, I do 8k only when its necesary, but it feels pretty smooth on that rpm range feeling like it wants more...
Author:  boostfreak [ Thu Sep 15, 2016 1:56 pm ]
Nice! This is with supa-elevation correction right?
Is the 1.8L transmission mounting flange the same as th 1.6 and 2.0? What is the deck height and stroke of that motor?
Author:  biglady112 [ Fri Sep 16, 2016 1:24 am ]
88mm stroke. Same deck height as a 2.0L. 81mm bore. The 1.6-2.4 narrow block Sirius motors all share the same bell housing pattern
The dyno numbers are corrected. That dyno usually has a 1.20-1.27 correction factor. It is a load bearing dynojet. The uncorrected numbers from that dyno are quite accurate for what are realistic numbers for our elevation.
Author:  antilag_200 [ Fri Sep 30, 2016 8:02 am ]
hope you are feeling better biglady hang in there
Author:  biglady112 [ Fri Sep 30, 2016 8:22 am ]
Wrong thread but, I am actually headed to the doctor now for a follow up. I had my third surgery monday. I have an infection of course. Three types of bacteria, including MRSA. I am sick of this and ready to be done with it
Author:  xxNocturnalxx [ Fri Sep 30, 2016 9:00 am ]
Good to hear from you Biglady, hang in there.
https://www.phpbb.com/
