It is currently Fri Apr 19, 2024 12:31 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
PostPosted: Fri Feb 12, 2010 3:54 am
i am posting this for my friend. the car is at my house right now.
-clean and clear title ready to go
-4g63t swap
-the motor cam out of a 92 eagle talon that had 105k miles on it. a tree feel on the talon so that is why we were able to get the motor.
-the head gasket was replaced and the head was completely rebuilt so it does not smoke at all
-we replaced the rod and main bearings with clevite 77 bearings before we swap the motor. the stock crank and bearings were perfect but we replaced the bearing any way since we took it out.
-new timing belt and tensioner
-still has stock balance shaft
-stock 14b in great condition with no smoke
-3" stainless steel down pipe that is currently dump underneath the car
-the motor run really good and has 160psi of compression straight across. I can send pics of the compression test if you like.
-urethane motor mounts
-car crank right up
-92 wiring harness and ecu
-1.8l 5 speed tranny
-tranny shifts great
-brand new 6 pucks stage 3 clutch
-brand new flywheel
-1.8l axles
-cxraing intercooler with custom intercooler pipe that is tig welded to fit perfectly
-custom j-pipe
-custom intake pipe
-sequential bov
615hp and 475tq at 23psi and 75shots
http://gadsm.org/showthread.php?t=37685
PostPosted: Fri Feb 12, 2010 3:59 am
PostPosted: Fri Feb 12, 2010 4:06 am
PostPosted: Fri Feb 12, 2010 4:31 am
-it has HID head lights
-it comes with the rims and tires. the tires still have 95-97% of life left on them.
-the car is located in geogia at the 30101 zip code.
-the paint is new but he did not pay to have some of the door dings and dent removed. over all it is pretty straight. it has no accident because the frame is complete straight
-the carpet is removed and it has one race seat right now.
-the air is removed but it is in the trunk
he like to get $3800 obo for it. if you have any question, feel free to call me at 6788609924 or pm me. if you want more pics and can get them for you.
PostPosted: Mon Feb 15, 2010 2:06 pm
bump. this car is running great.
PostPosted: Mon Feb 15, 2010 6:46 pm
That license plate = fail :P
PostPosted: Fri Feb 19, 2010 1:57 am
funny you said that because you are his idol. i can't stop him from mentioning your screen name. i think he beat off watching the videos you got on your site.
PostPosted: Fri Feb 19, 2010 2:03 am
Owner/Admin
:lmao:
PostPosted: Fri Feb 19, 2010 11:32 am
fap, fap, fap... :lol:
PostPosted: Wed Feb 24, 2010 3:09 am
bump
PostPosted: Sat Feb 27, 2010 2:28 am
this car is looking pretty clean after a little pressure wash. still waiting for a good home.
PostPosted: Tue Mar 09, 2010 2:47 am
sold
