FS: 1g/ 2g turbo parts http://4g61t.org/forum/viewtopic.php?f=4&t=31587 |
Author: | Twenty5psi [ Sat Jan 23, 2010 11:45 pm ] |
Post subject: | FS: 1g/ 2g turbo parts |
I have a bunch of parts from 2g's and 1g's I've parted out: 1g parts: 1gb hood-30 1ga hood-30 92 fwd axles-30 90 awd front axles-30 22 spline t-case-60 23 spline t-case-60 coil pack-25 aftermarket blue rad hoses-25 6 bolt awd flywheel-25 used clutch in good shape-25 act 6 bolt awd flywheel-120 radiator w/ fans-35 panasonic cd player w/ mounting kit-50 sony xplode rear 6x9's-20 awd megan 3" down pipe-75 1g gauge cluster with reverse indiglo light kit-35 mitsubishi vc that says mitsubishi on it, not the stock eclipse one-45 regular valve cover-35 ps pump alternator 3 pod gauge pod 90 awd 5 spd trans for parts, case is cracked-40 2g parts: 7 bolt longblock in good condition, ready to bolt in and go-400 7 bolt shortblock in good condition ready to put a head on and go-200 2g head-150 5 spd fwd tranny-325 rad w/ fans-40 2g doors in good shape with glass-35 each wiring harness-100 450cc injectors-55 new in box rear drilled rotors-40 2g mas-35 aluminum aftermarket intake pipe with filter and filter adapter-45 tb elbow-15 tan leather interior-driver seat is power-200 for set tan interior plastics-bo black airbags-45 tb with all sensors-35 hood-40 driver side fender-35 full ac and all parts-70 motor mounts-35 7 bolt oil pan-25 coil pack-25 crank sensor-25 aftermarket strut tower brace-25 weapon r coilovers-45 sunroof-45 7 bolt fwd flywheel 2gb foglights I can deliver some of the larger parts in the tri-state area for a gas fee. |
Author: | boosted2ndG [ Sat Feb 13, 2010 9:10 pm ] |
Post subject: | Re: 1g/ 2g turbo parts fs |
Is this stuff still for sale??? |
