It is currently Thu Apr 18, 2024 10:22 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: FS: 1g/ 2g turbo parts
PostPosted: Sat Jan 23, 2010 11:45 pm
I have a bunch of parts from 2g's and 1g's I've parted out:
1g parts:
1gb hood-30
1ga hood-30
92 fwd axles-30
90 awd front axles-30
22 spline t-case-60
23 spline t-case-60
coil pack-25
aftermarket blue rad hoses-25
6 bolt awd flywheel-25
used clutch in good shape-25
act 6 bolt awd flywheel-120
radiator w/ fans-35
panasonic cd player w/ mounting kit-50
sony xplode rear 6x9's-20
awd megan 3" down pipe-75
1g gauge cluster with reverse indiglo light kit-35
mitsubishi vc that says mitsubishi on it, not the stock eclipse one-45
regular valve cover-35
ps pump
alternator
3 pod gauge pod
90 awd 5 spd trans for parts, case is cracked-40
2g parts:
7 bolt longblock in good condition, ready to bolt in and go-400
7 bolt shortblock in good condition ready to put a head on and go-200
2g head-150
5 spd fwd tranny-325
rad w/ fans-40
2g doors in good shape with glass-35 each
wiring harness-100
450cc injectors-55
new in box rear drilled rotors-40
2g mas-35
aluminum aftermarket intake pipe with filter and filter adapter-45
tb elbow-15
tan leather interior-driver seat is power-200 for set
tan interior plastics-bo
black airbags-45
tb with all sensors-35
hood-40
driver side fender-35
full ac and all parts-70
motor mounts-35
7 bolt oil pan-25
coil pack-25
crank sensor-25
aftermarket strut tower brace-25
weapon r coilovers-45
sunroof-45
7 bolt fwd flywheel
2gb foglights
I can deliver some of the larger parts in the tri-state area for a gas fee.
PostPosted: Sat Feb 13, 2010 9:10 pm
Is this stuff still for sale???
Users browsing this forum: No registered users and 21 guests
