Well i just found out my girlfriend is pregnant so there goes my plans on building this car up.
I'll be totally honest about the car and tell you everything i can...here goes.
96k miles. Everything works, all lights work, no cracked glass, front tires good/back tires low. I drive it 350 miles a week without a hitch.
Body: Rot holes in the front of the quarter panels at the very bottom. Previous owner filled them with foam and painted it. It is repairable. small rust spots here and there and a blunt dend on the passenger side quarter. Marjority could easily be pushed out by hand. Undercarriage is solid i've had this car up on a lift.
Interior: Seats seams are pulling apart. Dash has some cracks. volume knob is missing. everything is intact.
Engine: runs great. SS header 11b turbo. Has a rebuilt 2.0 head with 2.0 cams. new timing belts, all new bearings and pistons rings. Does not smoke or leak oil but i use about a quart every 3k miles. new O2 sensor oil changed every 3k or less.
Trans: goes into gear every time. Feels a little stiff when it's very cold. new clutch.
Brakes are also new with brembo front rotors.
If you top the tank off you can smell the odor of gas but no leaks, to avoid this i don't fill over 3/4 and have no issues.
I did modify the hood and put an intake on it. Windows are tinted dark.
$1500 OBO
