It is currently Fri Apr 19, 2024 3:04 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Tue Dec 15, 2009 7:04 pm
This turbo has 280 miles on it. It was good while it lasted, but it is time for my friend to step up to something that is just rediculous. Turbo is as good as when it was installed earlier this spring. I will include two links about the turbo below. This turbo can be compared to a large GT30 or a small GT35.
The sale will include the following-
SPA 65mm turbo-280 miles
XS power open T3 manifold-280 miles, both flanges ported, wastegate tube modified and rewelded
Oil feed line
Short 2.5" downpipe- this faces straight down in front of the motor, is braced off of the factory downpipe bracing point on the front of the block, has both a wideband and factory 02 sensor bung, the flange that the pipe is connected to was custom made by a local machine shop out of stainless steel
38mm wastegate dump tube
This turbo has a divided .82A/R T3 housing.
Turbo and all corresponding parts are still mounted to the car and in good running order.
Help us put a rediculously large Borg Warner turbo on my friend's car.
http://www.brucesspeed.com/spa7000h.aspx
SPA-7000H
http://www.drivenmotoring.com/spa-turbos.html
$650 shipped including paypal fees
Steven Johnson
720-299-7057
biglady112@yahoo.com
paypal= biglady112@yahoo.com
1985 Mitsubishi Cordia
Build in progress
PostPosted: Thu Dec 24, 2009 6:43 pm
$550 shipped.
Build in progress
PostPosted: Sat Jan 02, 2010 1:01 pm
475 shipped
Build in progress
