It is currently Thu Apr 18, 2024 7:41 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: F/S MAFT PRO W/sensors
PostPosted: Thu Dec 10, 2009 6:33 pm
like the title says. i have a maft pro with all sensors to run speed density. also comes with 2g speed density harness, and weld in bung for ait sensor.
2g harness, 3 bar map sensor and bung are all brand new never used.
100 dollars for the new stuff alone. ill let it all go for 350 or 300 for everything but the weld in bung and 2g harness as ill prob use this when i switch to sd on dsmlink v3.
what you get with everything is used MAFT pro, used ait sensor, brand new gm 3bar map sensor, new 2g speed density harness, weld in bung for ait sensor.
everythign here is all you will need to install and tune your car on speed density. if you are running a 2g maff right now you can just plug the 2g speed density harness in and you wont have to run wires out to the engine bay. if your running a 1g maff you can wire in a 2g maff plug and run the harness as well.
all this alone would cost over 500.00 brand new. and just the maft pro units without sensors go for 350 on full throttles website regularly.
Andy
andyafp@aol.com
PostPosted: Sun Dec 13, 2009 10:35 pm
still have this. make me offers guys.
PostPosted: Tue Dec 22, 2009 1:39 am
200 cause i am WAY cheap...i am a DSM guy man...
PostPosted: Sun Jan 03, 2010 2:47 pm
SOLD.
