Contact: PM or text 615-788-6281
INFO:
This vehicle contains the all coveted 2jz-gte from the infamous Toyota Supra. It's a 3.0 liter twin-turbo inline 6 with 320 horsepower in stock form. The engine is mated to a matching A341E 4 speed automatic transmission.
The car retains ALL of it's factory options and accessories. Automatic climate control, power steering, cruise control, power door locks and power windows work flawlessly.
The stock 2jz-gte has been further upgraded with a 60-1 single turbo kit. The car put down a conservative 403 (on 14psi) horsepower to the wheels (Car is now running 17psi but I have not had it dynoed). The transmission shifts smooth and crisp in all gears.
Here is a full list of upgrades:
Toyota 2jz-gte engine (~40k miles)
Toyota 4 speed automatic transmission
Turbonetics 60-1 Turbo (currently running 17psi)
HKS SSQV blow off valve
HKS style wastegate
3 row intercooler
2.5" custom intercooler piping
All silicone couplers and t-bolt clamps
NGK AFX Wideband O2 sensor
Greddy purple 550cc injectors
Greddy E-manage Piggyback ECU (Tuned by RLZ Engineering)
Polished aluminum underdrive pulleys (stock Toyota crank pulley)
Twin electric cooling fans
Apexi EL mechanical boost gauge
3" custom exhaust with Megan Racing mufflers
6000k HID headlights
Eibach Springs
Fresh alignment
Cross drilled and slotted rotors
Two new tires
New alternator
New front lower ball joints
New timing belt
New water pump
New front main seal
New camshaft seals
New oil pan gasket
New Spark plugs (NGK BKR7E)
New toyota supra TT battery
All replaced less than 5k miles ago
Oil replaced every 2k miles
Cometic Headgasket (not sure of thickness, not installed)
The car is absolutly 100% done right. The car still has A/C that blows ice cold, power steering that is VERY smooth! You will not find this in MANY swaps! This swap was performed by a shop, not by me. I simply drove the car. The car just made a 700mile trip from when I went to get it. I don't like having 4 doors, so I have my eye set on something else.
I am also willing to let Carma or someone that actually knows these cars check the car out for you, so that you know you are getting a great car. It runs great and everything, and you are more than welcome to check it out.
I'm willing to work with any potential buyers to have this car shipped anywhere in the United States of America.
I may be interested in potential trades but I prefer to sell the car outright.
The price is 10,500 decently firm. I know what this car is worth.
If you have any further questions, please contact me by e-mail or telephone and I will respond immediately.
Carfreak70852@gmail.com
615-788-6281
