FS: 11.50's Pump Gas 3rd Gen Sedan http://4g61t.org/forum/viewtopic.php?f=4&t=30829 |
Page 1 of 2 |
Author: | 904g63summit [ Fri Oct 02, 2009 3:12 pm ] |
Post subject: | FS: 11.50's Pump Gas 3rd Gen Sedan |
1990 Eagle Summit DL base model Interior is great Exterior is good Mods -Stock 4g63t, 100k miles, All new gaskets and seals, 155 compression across all cylinders, has 10k miles on all parts put on the motor. -JMF Intake manifold, first version, flange milled flat by machine shop -FP2 cams -fidanza cam gears -EVO 3 16g -2g manifold and o2 housing -2.5'' exhaust -walbro 255 -denso 660's -custom tube and fin intercooler -Afco radiator -M and H 25'' tall drag radial with ALT wheels -92 laser turbo fwd auto trans with IPT rebuild kit, and shift kit -B&M trans cooler & Amsoil fluid -stock converter -ebay coilover kit and front springs, 750 eibach springs in the rear, monroe sensatrac shocks -Dave Katz Custom speed density code, speed based boost, and tune -AEM wastegate solenoid The car ran 11.57@ 119 with a 1.8 60ft It needs a better BOV and a working ISC, stock crushed bov leaks at 23 lbs. $5500 here is the shortcut to the 11.57 run http://www.youtube.com/watch?v=WNGtKKo-ObU here are some photos http://www.myphoto.com/904g63summit/9238/67921 http://www.myphoto.com/904g63summit/9238/67922 http://www.myphoto.com/904g63summit/9238/67919 http://www.myphoto.com/904g63summit/9238/67909 http://www.myphoto.com/904g63summit/9238/67908 http://www.myphoto.com/904g63summit/9238/67918 http://www.myphoto.com/904g63summit/9238/67915 http://www.myphoto.com/904g63summit/9238/67916 http://www.myphoto.com/904g63summit/9238/67913 http://www.myphoto.com/904g63summit/9238/67923 http://www.myphoto.com/904g63summit/9238/67910 |
Author: | cheaptalon [ Fri Oct 02, 2009 3:54 pm ] |
Post subject: | Re: FS: 11.50's Pump Gas 3rd Gen Sedan |
Cannot see photos without logging in. |
Author: | 904g63summit [ Sat Oct 03, 2009 10:50 am ] |
the pictures should be viewable now |
Author: | 904g63summit [ Sat Oct 10, 2009 9:30 am ] |
bump |
Author: | 904g63summit [ Sun Oct 18, 2009 11:14 am ] |
bump |
Author: | Phlipfreq [ Sun Oct 18, 2009 1:20 pm ] |
Its quick but take 50% off and a couple people might start thinking about it. |
Author: | Enter [ Sun Oct 18, 2009 1:55 pm ] |
3k and a lot of ppl would be on this incuding me |
Author: | 89Mirageman [ Sun Oct 18, 2009 2:40 pm ] |
Here we go again. Guys please, if you don't like the price, kindly hit the back button or PM him an offer. Don't clutter the thread with lowball offers. |
Author: | 904g63summit [ Mon Oct 19, 2009 9:57 am ] |
Its no big deal, I actually like to hear input on what you guys are thinking. I really didnt know what to offer, so I based it on how much it would cost to build this car as it sets, properly and with good parts. I dont see how you could do it any cheaper than my asking price. I understand CSMs are usually alot cheaper, but this car isnt a bucket of bolt, its put together properly, its never broken, and its pretty advanced for a CSM, based on the auto setup, MAP conversion, speed based boost control, and tunability with a stock eprom ecu. Id like to hear yalls opinions on the matter. |
Author: | fastvtgsx [ Mon Oct 19, 2009 11:58 am ] |
I think the price is pretty on, I know I have at least 5k in mine when all is said and done. GL with the sale. |
Author: | 904g63summit [ Sun Nov 01, 2009 3:25 pm ] |
bump |
Author: | The DSM guy [ Sun Nov 01, 2009 9:56 pm ] |
Makes me wonder what a swapped csm is worth.. I'm doing one now to drive for a short while and then sell... Hopefully make some money on it.. |
Author: | 904g63summit [ Tue Nov 03, 2009 10:42 pm ] |
What something is worth depends on many factors, someone may believe its priceless, someone else may think its not worth two nickels. I based this price on what it would cost to build this same exact vehicle. Minus about a grand, and all the work involved. |
Author: | 904g63summit [ Sat Nov 14, 2009 10:42 am ] |
bump |
Author: | 904g63summit [ Wed Nov 25, 2009 6:37 pm ] |
bump |
