It is currently Mon Oct 27, 2025 1:42 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 21 posts ]  Go to page 1 2 Next
PostPosted: Sun Feb 22, 2009 6:57 pm
Like the title says i'm after an engine wiring harness to suit my Cyborg. A Turbo Mirage/Colt harness would be perfect, but i'm willing to buy a DSM one provided you can get me pictures of the two dash plugs so I can make sure they'll match mine. The harness i'm after is to suit the cars with the older type CAS (i.e NOT the type that have the plug on the CAS itself)
I need one of these asap to get my daily driver running and can't find one in NZ.
Cheers
PostPosted: Sun Feb 22, 2009 7:15 pm
I'm assuming you would want a 90 dsm harness as it's most like the turbo colt's?
PostPosted: Sun Feb 22, 2009 8:50 pm
I'm not sure man. Whatever works... i'm not gonna be picky. I'd really like something that would plug straight in without having to change my CAS, throttle body, etc etc
PostPosted: Sun Feb 22, 2009 10:13 pm
The 90 dsm harness is the closest to a turbo colt harness as far as cas/ignition is concerned.
PostPosted: Sun Feb 22, 2009 10:22 pm
Cool, thats what i'm after then! :D
Are the two white dash plugs compatible?
PostPosted: Sun Feb 22, 2009 10:49 pm
It might be plug+play but if it isn't, Chris can do an adapter harness for you.
http://www.4g61t.org/forum/viewtopic.php?f=4&t=25358
PostPosted: Mon Mar 09, 2009 1:20 pm
Bump :)
PostPosted: Mon Mar 09, 2009 2:28 pm
None of the dsm engine harnesses are plug and play, you need an original 89 Colt/Mirage turbo harness for that.
PostPosted: Mon Mar 09, 2009 3:23 pm
I was under the impression that a '90 DSM turbo harness was the same?
PostPosted: Mon Mar 09, 2009 8:57 pm
As far as under the hood goes they are similar or maybe even identical but under the dash where it connects to the dash harness they are completely different.
PostPosted: Mon Mar 09, 2009 9:03 pm
I take that back, even under the hood they are not identical in terms of wire length, but the plugs are all the same.
PostPosted: Mon Mar 09, 2009 9:10 pm
Do you mean all the plugs are the same, or just the under hood ones? If the dash plugs are different, i'm gonna have the same problems as I have with the VR-4 loom I picked up.
PostPosted: Mon Mar 09, 2009 9:13 pm
Dash plugs are different for sure. The only plug and play harness will be a turbo csm one.
PostPosted: Mon Mar 09, 2009 9:14 pm
Owner/Admin
sorry the last one I ran across had the harness cut up, getting a colt or a mirage harness is super hard to come by the way of junkyard snowdevl
PostPosted: Mon Mar 09, 2009 9:25 pm
Yeah I figured. So what do the 1.5 guys use when 4G63 swapping?
