It is currently Tue Oct 28, 2025 4:41 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Sat Mar 07, 2009 4:46 pm
Was: 92GVR4#847
I have a stock intercooler with most piping from my GVR4. $65 shipped
also have some stock 92 gvr4 wheels in decent shape with no major damage. $150 for local pick up.
last I have my stock 14b turbo off my gvr4 that has zero shaft play in & out or side to side with oil. It has a tiny, and I do mean tiny bit side to side with no oil. It is in great condition with no blown seals, leaks, or broken bolts. Only issue is it does have a small crack on the turbine inlet which is common for these. $150 shipped for it and that included the 1g O2 housing and a new 2g oem O2 gasket.
 Post subject: Re: GVR4 goodies
PostPosted: Sat Mar 07, 2009 4:52 pm
You are under the post limit, also next time you post, add FS or WTB in your subject line. Unless you have someone vouch for you, you cannot sell stuff. http://www.4g61t.org/forum/viewtopic.php?f=4&t=12499
V/R
-Dave
PostPosted: Sat Mar 07, 2009 9:50 pm
Thread re-opened, SLobra vouches for you. Any positive/negative feedback will go to him also.
PostPosted: Sat Mar 07, 2009 10:38 pm
He's been on the forum for a while and had more than 20 posts before PaulMezz did his big switch a while back.
PostPosted: Sun Mar 08, 2009 8:25 pm
Was: 92GVR4#847
You can also check my feedback on the gvr4 board which is all positive.
thanks for the vouch Slobra
PostPosted: Wed Mar 11, 2009 6:48 am
Was: 92GVR4#847
I also have a Evo III manifold in great shape with no cracks or damage. The outlet has been ported to remove the step and it comes with a blingin stainless steel heat shield. $110 shipped for both.
also have a HKS SSQ bov adapter. dont know what it goes to but it goes for $80 on the net so I will take $40 shipped.
last I have a stock SRT4 intercooler in great shape. $65 shipped
also pics of the turbo from my original post.
