| 4G61t block and 89 Mirage turbo ECU(non Eprom) http://4g61t.org/forum/viewtopic.php?f=4&t=27018 |
Page 1 of 2 |
| Author: | TrevTec [ Fri Nov 21, 2008 10:35 am ] |
| Post subject: | 4G61t block and 89 Mirage turbo ECU(non Eprom) |
Looking to sell my 1.6 parts. 4G61 Block, I'll throw in the head for free but it has bent valves $150 + shipping 1.6 Mirage turbo ECU, good caps, NON EPROM $75 + shipping |
| Author: | TrevTec [ Fri Nov 21, 2008 10:37 am ] |
| Post subject: | Re: 4G61t block and 89 Mirage turbo ECU(non Eprom) |
Grey Top 4G61 Injectors (370cc??) $100 shipped |
| Author: | Rhdae86 [ Fri Nov 21, 2008 11:49 am ] |
i'll take the ECU RIGHT NOW Call me bro 562-612-1529 im located in Socal and would like it shipped As Soon as possible. (this is my thread on my Search for the ecu http://www.4g61t.org/forum/viewtopic.php?f=6&t=26992) Found out my caps were leaking so i for surely need to pick yours up,mean while i get my original ecu refurbished,plus its always good to have an extra. Let me know,i can have a buddy Paypal you right now. |
| Author: | TrevTec [ Fri Nov 21, 2008 12:10 pm ] |
I will call you in a while when I get to work. Trevtecauto@aol.com is my paypal, add about $10 for shipping |
| Author: | Rhdae86 [ Fri Nov 21, 2008 12:38 pm ] |
Alright!! Looks like i owe Tonus a Lunch! |
| Author: | Rhdae86 [ Fri Nov 21, 2008 1:17 pm ] |
The money is now being sent threw Pay-Pal. Call me when you get it 562-612-1529 |
| Author: | 89D15CRX [ Fri Nov 21, 2008 1:40 pm ] |
Quote: Grey Top 4G61 Injectors (370cc??)
They're 390s. $100 shipped |
| Author: | Rhdae86 [ Fri Nov 21, 2008 1:45 pm ] |
Payment is Now in your account bro! hit me up |
| Author: | TrevTec [ Fri Nov 21, 2008 1:57 pm ] |
I tested this ECU in a 90 DSM, and it seemed to run ok. BUT, I just opened it up and there is a little burn mark next to one of the caps. I just want you to see it before I send it. ![]() ![]() If you dont like that, let me know. |
| Author: | Rhdae86 [ Fri Nov 21, 2008 2:43 pm ] |
Well the Payment has been sent already and i only bought it to fix my Problem So send it. you said it had good caps,Lets see what happends.Hopefully this one can last meanwhile i get my stock one fixed. |
| Author: | CaptainTonus [ Fri Nov 21, 2008 2:51 pm ] |
Quote: you said it had good caps,Lets see what happends.Hopefully this one can last meanwhile i get my stock one fixed.
Your stock one is probably fried beyond repair, it's a paperweight now. This one will work fine, but I would recommend having the caps replaced so that you don't have to worry about it ever again.
| Author: | Rhdae86 [ Fri Nov 21, 2008 3:41 pm ] |
i just ordered a set of caps for my stock ecu. So basically instead of getting those brand new caps and putting them on my old ecu i should install them on This new ecu im getting? |
| Author: | SpinMasta11 [ Fri Nov 21, 2008 5:08 pm ] |
If you dont have any soldering experience, or havent replaced capacitors before, I wouldnt recommend you trying this on your own, when the caps start leaking, the pads can get tore up pretty easily taking the old caps out, unless you know what your doing. Like tonus said, your gonna want to replace those caps in that new ecu your getting, the capacitors they put in these ecus should all be changed over. If you cant find anyone local to replace those caps for you, I will do it dirt cheap. Also your ecu thats failing is probably still salvagable, I havent worked on one yet that wasnt salvagable, so dont toss it just yet, I would like to take a look at it for you and try to fix it, if you dont mind paying just shipping, its kinda a hobby of mine. |
| Author: | Rhdae86 [ Sat Nov 22, 2008 2:45 am ] |
SpinMasta - i'll be for surely talking to you bro. TrevTec - Im just curious When the arrival Date the postal service told you it'll be at my place(Its because im leaving in 5 days from now)Wouldnt mind slappin it on just to Drive around the block with No issues. |
| Author: | TrevTec [ Sun Nov 23, 2008 11:03 am ] |
Sent it USPS Priority, 2 day, Should be there soon |
| Page 1 of 2 | All times are UTC-05:00 |
