http://4g61t.org/forum/
NOT MINE, 89 Summit Sedan 5spd on EBAY
http://4g61t.org/forum/viewtopic.php?f=4&t=26971
Page 1 of 2
Author:  G4CS [ Mon Nov 17, 2008 9:57 am ]
Post subject:  NOT MINE, 89 Summit Sedan 5spd on EBAY
Just throwing this out there incase anybody missed it, 89 5spd sedan on ebay.
http://cgi.ebay.com/ebaymotors/1989-eag ... dZViewItem
Author:  89Mirageman [ Mon Nov 17, 2008 10:26 am ]
Post subject:  Re: NOT MINE, 89 Summit Sedan 5spd on EBAY
Thats a rare 1.6 4G61 car too as it has the turbo wheels and interior. It needs more than a timing belt though, pretty sure it has some bent valves. Still looks like a nice car if someone can snatch it up cheap.
Author:  turbomirage89 [ Mon Nov 17, 2008 2:55 pm ]
You would have to install a whole new turbo wiring harness if this thing if you wanted to install the turbo motor right?
Author:  89Mirageman [ Mon Nov 17, 2008 3:47 pm ]
Nope, just add a handful of wires to the existing harness. One for the maf, knock sensor and injector resistor pack. All mounts are there too.
Author:  CaptainTonus [ Mon Nov 17, 2008 4:03 pm ]
It has the axles you need also.
Author:  89Mirageman [ Mon Nov 17, 2008 4:29 pm ]
You could probably run the F5M22 tranny that comes with it too if you took it easy on it.
Author:  Natedog [ Mon Nov 17, 2008 4:38 pm ]
I've found 3 of these are the yards and none of them had equal length axles. Maybe someone had replaced them?
Author:  CaptainTonus [ Mon Nov 17, 2008 4:49 pm ]
You found 3 different 4g61 Summits in the junkyard? Only the 4g61 cars had the turbo axles.
Author:  89Mirageman [ Mon Nov 17, 2008 5:11 pm ]
Actually the NA 4G61 cars didn't have the turbo axles, well the one on the drivers side isn't anyway. Its a long axle like the 4G15 cars but the part that snaps in the diff is different. I'm guessing the passenger side axle is the same on all 4G61 cars, turbo or not.
Author:  CaptainTonus [ Mon Nov 17, 2008 5:21 pm ]
According to my catalogs, the part #'s are the same between the '89 Turbo CSM's and the 4G61 Summits--as long as they're both manual transmission cars.
Author:  cheaptalon [ Mon Nov 17, 2008 5:55 pm ]
I want.
Author:  Natedog [ Tue Nov 18, 2008 3:37 am ]
Yup, 3 different 4g61 Summits, all with one long axle and one short....
Author:  cheaptalon [ Tue Nov 18, 2008 2:12 pm ]
Is anyone on the forum bidding on this? I don't want to get into a bidding war with someone on the forum and have one of us get screwed out of a nice car.
Author:  92 TSi AWD [ Tue Nov 18, 2008 7:37 pm ]
FYI, His reserve is set at 400 bucks. I was interested but its a little too far from Northeastern PA.
-Mike
Author:  Incoltnito [ Tue Nov 18, 2008 7:44 pm ]
I just tore the turbo seats out of a summit just like this. And I'm sick....realized it had turbo wheels, and I was about to buy them until I discovered there were only three turbo wheels on the car!!
Page 1 of 2 All times are UTC-05:00
https://www.phpbb.com/
