It is currently Sun Oct 26, 2025 10:03 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Fri Nov 21, 2008 4:47 am
I really need a metal coolant supply and a metal oil supply line for a 14b as well as ALL of the banjo bolts to attach them to the turbo. I have the oil and coolant drain lines but I need all three of the banjo bolts to attach the lines to the turbo as well as the metal supply lines themselves. Anyone that can help me is my savior right now. I have the money in hand. I REALLY don't want to go to the dealer for it.
PostPosted: Fri Nov 21, 2008 5:48 am
I should have them. Will check today.
PostPosted: Fri Nov 21, 2008 11:00 am
i think I have both supply lines and all of the banjo bolts. .48 cents plus shipping. I will check when i get home from work.
PostPosted: Fri Nov 21, 2008 11:37 pm
Anyone?
PostPosted: Sun Nov 23, 2008 6:21 pm
Can someone help me out please? This is the last part I need to get my ride running.
PostPosted: Sun Nov 23, 2008 11:39 pm
When you receive them, please explore the safest route to go for decoking any of those passages that may have become restricted or have things lightly clinging to the walls. Many a time people have bolted up used parts and found out they keep blowing turbos, or worse when stuff comes out of their used lines. I would suggest using over cleaner or something strong like carburettor cleaner (the REALLY harsh don't get it on your hands oMFG it stinks get that crap out of our house I hate you says the wife stuff), but I don't want to tell you to use something that could effect the longevity of the part, as the ends must be soldered somehow. Maybe some people have some experience with cleaning the lines and no ill effects in the long run for them.
