I need..................1989- 1991 mirage.colt. summit stuffs....
stock power window full wiring harness ---
Bought
stock power side mirror switch with wiring assembly ---
Bought
camber plates ----
Bought
the plate/bracket that holds the shift boot to the center console----
Bought
and som O.Z. F1 cup rims(stock 05 up lancers) size 15 or 16 4x114
or 16 enkei RPF1 or knock off brand size 16x7 4x114 -----pending
should I buy this?
http://cgi.ebay.com/ebaymotors/Dodge-Co ... enameZWD1V
I also want some lowering springs that are close to 2 inches drop tha fits a sedan,,,, or should I go coil overs? any suggestion in brand?....----pending
I also need the liner that went to the sides inside the trunk because mine you can see the body/metal part..... or did the mirage didnt come with those compared to the 4g up? [b
]--->I still need this[/b]
does anyone have a front strut bar that looks like these
http://cgi.ebay.com/ebaymotors/97-98-99 ... enameZWDVW
or will this from the 5g work for ours?
..... i will be listing more later on....
