It is currently Sat Apr 27, 2024 2:22 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Sat Aug 02, 2008 12:32 am
The Good:
1996 Eagle Talon AWD Turbo (Clear Title)
133k miles on the Chassis (has been repainted, possible fender bender)
Working Sunroof
6 bolt engine swap Approx. 150k bottom end, with 25k miles on rebuild head.
14b Turbo
New Timing Belt
New Water Pump
Freshly rebuild Front axles
ACT 2600 Pressure plate, with stock replacement disc
Stainless Steel Clutch line
Stock exhaust with fart can (Maybe this should be in the bad section)
Transmission has been rebuilt at some point, unsure when but shifts smooth, and has been painted...
KYB GR2 Struts on rear
Mazda RX7 wheels with like new Goodyear Eagle F1 Tires
Brand new o2 Sensor, and NGK plugs
1/2 tank of premium Shell Gas :D
The bad:
Check engine light is on, due to the 6 bolt swap. I can bypass this by installing a resistor, but if a person were buying this car to modify, DSM Link Software for tuning, has provisions to ignore the false code.
The front brakes need changed and bled.
The passenger side window controls have fallen down inside the panel.
Engine sputters at start up till about 2k rpm, usually clears up when car warms up.
I'm tired of working on this thing... $4500 Will entertain reasonable offers, Or partial trades on white or silver Turbo Mirage / Colt. Thanks
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Thu Aug 07, 2008 12:24 pm
Price drop $4000, Thanks
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Aug 20, 2008 5:58 pm
Bump...
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
