It is currently Thu Feb 27, 2020 5:20 am
PostPosted: Wed May 24, 2017 8:47 pm
Over the years I have read hundreds of threads on this website. I have learned so much and I have finally done a build and want to share it with people.
However, I do not know how to add pictures.
Should I just make a slideshow video and put it on youtube and put a link to it in the post? Or would you guys rather see pictures?
I heavily photo documented EVERYTHING as this was my first swap and conversion. I also posted everything on Facebook.
In short, I swapped a manual engine & trans into an automatic body, and installed power steering on an engine which did not have power steering.
So I did an engine swap, manual conversion, and power steering conversion.
It was my first time pulling an engine.. let alone 2. I did everything in 3 days, completely by myself excluded removal of the first engine because I knew nothing about cv axles and was scared to tackle it on my own. I thought it was going to be much harder than it was. Probably like the torque converter replacement on my 1994 ram that I am still too scared to do.
PostPosted: Wed May 24, 2017 10:32 pm
i use photobucket.. others use a diff site.. basically u upload pics to that site then there are links u copy and paste here and they show up... hope that helps.
PostPosted: Wed May 24, 2017 11:55 pm
Steve is right^^.
But I sugest you use postimage.org to host your pics
It's far less bogged down with advertisements and pop ups
PostPosted: Thu May 25, 2017 11:13 pm
well if It's easier for you to make a youtube video then you could do it that way.
Abe
PostPosted: Tue May 30, 2017 11:05 am
The gallery is technically installed and running but we have only uploaded things there temporarily. Essentially no reason it won't be up soon. No timeline was set behind the scenes as of yet for its full front page return.
