well to me it would only be useful for a show car for the looks.. deleting the turbo to add the carbs would drop the HP way down. also you need to look at all the other issues you might come across like.. how will it get good/even airflow? will they hit the firewall? fuel return to the tank..carbs dont have this option... lots of lil things like this you need to look into .. now if you built a NT motor for more power and do this it might be kewl. but would cost alot more cause of the build.
either way its a very interesting idea..
My 83 Rabbit had the same engine layout, intake in the back. The manifold was stubby, and I could only run short horns, but it worked great. As far as return lines, that's easy. Just cap the line in the bay and save it for an eventual return to EFI
![:)](./images/smilies/icon_smile.gif)
. I've got a cabinet full of carb stuff, and balancing/tuning tools, so the setup would be easy. I've even got a couple of bypass FPRs to allow for the stock fuel pump to be used to provide 4 psi of pressure for the carbs, and send the rest back to the tank.
Anyway, still not sure, just thinking out loud to stave off the boredom, lol.
