It is currently Mon Oct 27, 2025 10:34 pm
PostPosted: Fri Apr 06, 2012 8:49 pm
On my summit wagon I am using an F5M22 trans from a 1g na dsm. At 70 mph its taching around 3200 rpm's. If I were to go to a larger rim with shorter tires would this make it tach higher or lower in 5th at 70 mph? I'm thinking the smaller diameter will make it tach up higher but I could be wrong.
PostPosted: Fri Apr 06, 2012 8:58 pm
It totally depends on the overall diameter of the tire. What size tire are you wanting to change to? Also, using a different size tire than what the speedometer is calibrated for(which would be the OE size) will result in the speedometer reading incorrectly. If the new tire size is 5% larger than the OE size then the speedometer will read 5% slower than you are actually going as the speedometer gear is driven by the differential itself.
PostPosted: Fri Apr 06, 2012 10:35 pm
Silly question but if the new tire is shorter when sitting beside the old one then the overall diameter would have to be less wouldn't it?
PostPosted: Fri Apr 06, 2012 11:11 pm
i tried that before..but when u put it on a rim..stretch it to fit then add air it wasnt the same size I thought it was.... either tire rack..or discount tire has a wheel tire calculator to check the diff sizes.
PostPosted: Fri Apr 06, 2012 11:33 pm
The tires in question are mounted and inflated. Even though the stockers are 14's and these are 16's the 16's are an inch or so shorter. This makes me think they will spin faster causing shorter gearing. Something I don't want if its already taching 3200 rpm's at 70 mph.
PostPosted: Sat Apr 07, 2012 7:20 am
Shorter tire equals less circumference, that means more revolutions to travel the same distance as a larger tire, making your speedometer read faster than you are really traveling. You would not see a difference in your tach and speedometer because their relationship has not been changed, only the actual speed of your car would be different. This theory is a good way to beat speeding tickets, put a larger diameter tire on your car after you get a ticket then have it calibrated, it'll show your speedometer was reading the speed limit, but the larger tires were making it go faster than you thought
PostPosted: Tue Apr 10, 2012 12:38 pm
i tried this on my truck to get better mpg. i went from a 245/60/16 to a 265/60/16 thinking that the taller sidewall would increase the overall tire size, which it did. from my understanding the first number is the tire width and the second number is the % of the width to get how tall your sidewall is. third number is rim size. with the truck it gave me a taller tire but also increased the surface area in contact with the ground, thus more friction. mpg didnt change. lol
PostPosted: Tue Apr 24, 2012 5:18 am
Not only will the larger diameter affect the speedometer reading it should also affect mileage. If you calculate the circumference which will equate to a roll out distance you can figure the percentage difference of each size tire. Chances are your odometer will say you went less distance than you actually did.
PostPosted: Sat Apr 28, 2012 9:03 am
On my Colt I run 195/60x15s to get a taller tire for lower rpm. They aren't good for performance as the sidewall is tall and flexible but I did it for mileage. Yes, the odometer will be off. Just measure the accuracy via mile markers on the hwy to get the ratio. I hand calculate mileage every tank and I have to divide by .9428 to get my actual distance traveled.
I did an experiment on my old fwd Talon. I put 4 donut spare tire rims on it with old VW Beetle size tires, 165/80x15s. Of course it handled like stink but I gained 4mpg just from the tires having less rolling resistance.
