It is currently Sun Oct 26, 2025 4:46 pm
PostPosted: Sat Jan 21, 2006 6:33 pm
good bye crappy rotors! My first caliper rebuild went great. Pass. side hub is shattered. How?, I don't know. Luckily I purchased a hub, spindle, caliper/hardware from a 4g61t. Smooth sailing untill the caliper wouldn't clear the pads/rotors. The swear jar then exploded. The width of the rotors and pads combined are approximately 55mm thick. The caliper's inside width is somewere around 50mm; piston compressed. 4g61t calipers??? Obviously not. Purchased from a private party last April gives no chance of a refund. This really bites! Here's what I found through my resources,
General specs for 1.6 Front disc brake:
Rotor thickness 24mm(.94") Limit 22.4mm(.882")
Pad thickness 15.5mm(.61") Limit 2mm(.08")
:wall:
PostPosted: Sat Jan 21, 2006 7:29 pm
That sucks.
I drink your MILKSHAKE! I DRINK IT UP!
PostPosted: Sat Jan 21, 2006 7:57 pm
WHy dont you just buy some new calipers instead of rebuilding them?
I got mine for like $50 for both fronts.
89' Mitsubishi Mirage Turbo.
PostPosted: Mon Jan 23, 2006 1:46 am
Where?
89 colt 4g61t swap (under further construction)
92 talon awd (for sale/needs motor)
PostPosted: Mon Jan 23, 2006 4:16 pm
Where?
I got them at Acme Auto, but they only have them in Connecticut. They were re-man's from A1 Cardone.
PostPosted: Tue Jan 24, 2006 3:46 am
Advance Auto Parts carries that brand as well, doubt they are that cheap though.
