It is currently Tue Oct 28, 2025 9:18 pm
 Post subject: U S jdm bumpers
PostPosted: Fri Sep 09, 2005 5:37 pm
anyone know if there are any jdm bumpers for sedans? im currently chopping mine up . so far so good. now i need to figure out a way to mount it. the rear bumper weighs around 25-30 lbs and has a foam that can be used as reinforcement and to hold the rear bumper cover on. this guy on galant vr4 did it to his galant and his bumper looks really good (like a jdm). all responses appreciated. and yes i searched. :o if it works out im planning to do the other bumper too.
im not a retard, im just too slow for your taste
PostPosted: Fri Sep 09, 2005 6:24 pm
The cyborg bumper is as close as you're gonna come to a JDM bumper
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Fri Sep 09, 2005 6:35 pm
i'm still confused as to what the hell you're asking??? how to make a usdm look jdm???
 Post subject: bumpers
PostPosted: Sat Sep 10, 2005 7:58 am
someone has done this already with a galant vr4. our bumpers have two shades on them if you look at the bumpercover. one is the gray part with a red stripe and the one that is closest to the grill which is the same color of the car itself. now, it has two reinforcements, the regular metal rusted heavy bumper and the foam reinforcements. japanese bumpers are much nicer, hence , people want them. i cut the section out to make it like the jdm ones instead of having a real big bumper sticking out, you have a real bumper but smaller like the jdm's. understand? this guy couldnt find jdm ones so he cut and fit his to make it look more like jdm. and it looks awesome. just a tid bit smaller. so he still has his bumpers and all but he has made his car lighter by: removing the old metal rusted unit that was falling out and replacing it with the foam/plastic type that the bumper comes with or you can get a plastic one which 1. will not rust and 2. is much lighter than the stock one. i already noticed a difference in the handling of the car since i removed the old rusted piece. so you still have the bumper and reinforcement but its much lighter and durable. so , do you understand now?
PostPosted: Sat Sep 10, 2005 8:41 am
Regardless of fitment, the only thing that saved my life and the GF's when we were hit in the front section was A) getting hit directly inline with the front bumper, and B) having the metal rebar still attached to absorb a collision of 50kmh(us) - 50kmh(the idiot) at right angles. Something very serious to think about when you are tweaking an already mentioned "tin can" of a vehicle. If we had been hit in the door, it would have been game over for me. Something very serious to think about. Look is one thing but if you don't at least engineer it to the standard the factory did for our cars and their frame design, then you are taking big chances on behalf of yourself and all your passengers. :-?
PostPosted: Sat Sep 10, 2005 9:44 am
you are correct , but this is the way they are sold in japan and are functional, lighter and absorb as much as the regular bumpers do. take a look at what is supporting the bumper itself. upon inspection its only a thin sheet of metal. that is what holds the bumper on the car. this piece of metal is actually weaker than the bumper itself. i thought about this myself. im mr. play it safe so that you know. and if your hit on a frontal, rear collision, or any other collision whatsoever, a heavy bumper isnt going to do much for you unless the under structure is stronger than the bumper itself. i was looking at the rear of the car yesterday and i noticed this, the heavyyyyyy bumper is held by four screws onto this layered sheet of metal that 1. i can look behind it and 2. i can bend it with a set of plyers very easily. so, think what would happen in a case where youre hit in the rear, the bumper will either be ripped off and the rear end that holds the bumper in place will be crushed like a soda can. or the bumper will stay on (without damage) and the rear will be bent out of shape. the foam under neath it is just as strong and lighter too. so for someone who actually plays it safe (exagerratedly so) it freaked me out to see what was actually holding such a heavy duty bumper. plus, my bumper was falling out and rusted. what to do in this case? well ill just modify it instead of going and looking for one that i probably wont find anyways. another thing.. what holds the jdm bumpers in place? where can you get a cyborg bumper and what holds that in place?
 Post subject: Re: bumpers
PostPosted: Sat Sep 10, 2005 2:29 pm
Ever heard of crumple zones? The "squishing like a tin can" is what likely saves your ass.
Darin
1986 GMC 3/4 Ton 4x4 Diesel (soon to be Greasel)
1993 Colt GL
 Post subject: jdm
PostPosted: Sat Sep 10, 2005 3:20 pm
OMG. please read what ive described above. the heavyyyy metal bumper is supported by thin pieces of sheet metal that i can bend with my bare hands. in an accident the bumper will not bend, the tin can part of your car will. get it? i already had this problem before with another car i had. the car hit the back side of my car and the bumper ripped off and the sheet metal bent up . the bumper was still good but what the part of the car that holds the bumper bent like crazy. understand now. whats the purpose of carrying around so much metal for then? the plastic support is enough.
PostPosted: Sat Sep 10, 2005 4:09 pm
the bumper is there to protect in low speed (aka 15mph and lower) crashes. but it also has the added purpose in high speed crashes to keep the car somewhat together in the event of a crash. think of it as a really strong ziptie trying to hold a hollow point bullet together. the bullet is gonna fragment a LOT more without something trying to keep it together. though it doesn't help much, it could still save your life. just fyi... in the end it's up to you to determine what you want to do, but if you do replace it, good luck passing inspection unless you have a hookup somewhere.
 Post subject: jdm
PostPosted: Sat Sep 10, 2005 6:12 pm
what holds jdm bumpers? do they have a metal bumper? and where can i find whole front and rear jdm bumpers for my sedan? man i wish i knew how to read japanese so that i can read those jap websites on our cars and get the good jap stuff for my car. oh well. any ideas?
PostPosted: Sat Sep 10, 2005 6:54 pm
Are the JDM or Toms replicas available from anyone anywhere anymore?
 Post subject: jdm
PostPosted: Sun Sep 11, 2005 10:25 am
the car will still have the bumper on. what im trying to do is shave it a little bit. the old rust metal bumper is not good so ill be replacing it with the foam type bumper (which looks like has some plastic skeleton in it) anyways right now im trimming and looking for bracketry to put it up. when i do ill see if i can get some pics up.
 Post subject: rear bumper
PostPosted: Mon Sep 19, 2005 8:41 pm
i modified my rear bumper. now its 30lbs lighter and looks like a jdm one. real nice. had to make custom brackets but it looks ten times better than before and... it looks jdm stock. :o its just a smaller version of our regular bumpers . sorry i got no camera right now but ill see what i can do.
PostPosted: Mon Sep 19, 2005 9:00 pm
:pics:
:D
PostPosted: Tue Sep 20, 2005 4:42 am
Yeah, we want pics! :drinkers:
Got rabies?
