It is currently Wed Jun 05, 2024 6:24 pm
Post new topic  Reply to topic  [ 87 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Sat Mar 02, 2013 7:29 pm
I just checked my K Sport camber plates, they are offset just like the factory is.
PostPosted: Sat Mar 02, 2013 11:17 pm
That's one thing I really hate about my Yoshifab plates. They removed my caster.
PostPosted: Sat Mar 02, 2013 11:32 pm
Shawn J,
That is great information, thank you. K-Sport camber plates are factory offset, Yoshi fab are not offset to maintain factory caster.
Coltsfan,
Did you end up installing SuperPro bushings to your control arms? Which arms were used and which bushing part #'s?
PostPosted: Sun Mar 03, 2013 12:31 am
Yes I used Superpro bushings for a base model, with base model arms. I don't recall the number off hand, but I can get it if you need it. They are the ones with no caster correction.
EDIT: SPF1140K
PostPosted: Sun Mar 03, 2013 9:55 am
Great update, thank you.
PostPosted: Mon Mar 04, 2013 6:06 am
What are the negative qualities of removing caster/running yoshifab plates?
PostPosted: Mon Mar 04, 2013 7:21 am
Steering issues. Coming out of corners at speed can be achieved better with more caster. Most racers run as much positive caster as they can get. I "think" it may have to do some returnablility after a turn but cannot remember if that is the TOOT angles mainly built in to the geometry of the knuckle.
Coltsfan, any thoughts?
PostPosted: Mon Mar 04, 2013 1:08 pm
Yes, plus better high speed stability with more positive caster.
PostPosted: Mon Mar 04, 2013 6:25 pm
FWIW, I never noticed any difference whatsoever when I swapped over to these camber plates, and I used to rail my car a lot through the twisties.
PostPosted: Mon Mar 04, 2013 7:27 pm
I does help bring the wheel back to center on it's own, but it really has more to do with how it plants the wheels into a corner. I autocross my car, and anything I can do to keep it from plowing into tight sharp turns is a big plus.
PostPosted: Tue Mar 05, 2013 1:53 am
Thanks guys, Tonus I bought your old set-up from Cheaptalon and am debating on weather or not to leave the yoshifab plates in but since I'm just doing straight line for now I won't worry about it too much I guess. I just never noticed the Yoshifab plates were centered until I seen this thread.
PostPosted: Tue Mar 05, 2013 5:32 am
More info here : http://www.4g61t.org/forum/viewtopic.php?f=22&t=36509
