It is currently Thu Oct 23, 2025 10:10 am
 Post subject: Re: That's no good.
PostPosted: Thu Apr 07, 2011 1:25 am
Have you ever tried to drill out a broken bolt extractor? Been there done that :(
PostPosted: Thu Apr 07, 2011 9:06 am
It's like trying to drill out a broken tap. It doesn't happen, usually the tap/bolt extractor is as hard as or harder than the drill bits you would use. So you cannot win.
PostPosted: Thu Apr 07, 2011 9:39 am
The factory bolts are pretty soft. AS long as you center the hole and get a good hole drilled you cant fail. The secret is to use WD-40, slow speed and lots of pressure.
PostPosted: Thu Apr 07, 2011 10:58 am
PostPosted: Thu Apr 07, 2011 11:00 am
You can drill and extract that. Buy a pack quality dremel bits and keep it cool while you drill.
Did you bottom out the bolts somehow?
'18 X5
'19 M5 Comp
'17 Fiesta ST
 Post subject: Re: now it's good.
PostPosted: Mon Dec 19, 2011 2:21 am
I think I found a solution to my problem finally:
Picked this up earlier in the week. I'm going to miss that little 1.6 :P
PostPosted: Mon Dec 19, 2011 9:17 am
I like that solution 8)
PostPosted: Mon Dec 19, 2011 2:16 pm
That's not going to work unless you pull the engine.
