It is currently Sun Apr 28, 2024 11:39 am
PostPosted: Sun Mar 28, 2004 5:03 pm
Just installed the rear mount and I'm very happy. Reduced engine movement alot without NVH issues.
Install was not hard, but took a little longer than I expected.
After removing the 3 bolts that hold the mount I realized it wont come out without either dropping the crossmember it was bolted to or removing the bracket from the block. I removed the bracket from the block (just 2 bolts).
The rubber portion of the stock mount has steel sleave around it that need to come out before putting in the new inserts. I used a saw to cut thru one of the sides from the inside and then used a screwdriver and a hammer to colapse the metal sleave until it fell out.
The new insert slides right in, no press needed. Great mod for $35.
PostPosted: Mon Jun 07, 2004 2:02 am
where did you buy the insert?
Thanks
alan
PostPosted: Sun Sep 12, 2004 8:54 pm
ya both of my mounts (front and rear)are shot and i need a couple of them
1987 Dodge colt premier 4 door g32bt running!!!! 3speed automatics suck!
PostPosted: Sun Sep 12, 2004 9:34 pm
here
http://www.prostreetonline.com/pso/page ... %20Inserts
89 mirage 4g61t
PostPosted: Sun Sep 12, 2004 11:48 pm
the front mount off a DSM does not fit -fyi
Corvette Beatin, Viper Eatin, SKEET-SKEET-SKEETIN...
PostPosted: Mon Sep 13, 2004 12:42 am
I just ordered 2 rear mounts they're the the same if you compare them. Thats what I use right now and it works great.
White 89 Mirage
4g63t - t3/t4 57/63, SFP manifold, tial gate, ex honed manifold, built head, 27x8x3 FMIC, 3in GM maf
PostPosted: Wed Mar 09, 2005 10:52 pm
Dsm inserts don't work unless you cut them to fit.
PostPosted: Thu Mar 10, 2005 12:43 pm
WRONG!!!
they actually do fit, you just have to find which ones do...
like 2 tranny mounts, 1 rear mount and the front is just a tiny insert (garbage) so just fill that one.
PostPosted: Mon Apr 04, 2005 6:40 pm
Not Wrong! The rubber part of the 61T mounts are smaller in diameter than those from a 63T. So What I had to do was cut the inserts to fit into the 61T mounts. I burned the whole rubber part out of the mount. I then cut the urethane mount to fit the hole, then stuffed it.
PostPosted: Tue Apr 05, 2005 11:51 am
i used a rear dsm mount for the rear mount.
i used a dsm tranny mount for the timing belt mount and it will also fit the tranny mount.
the front i filled with urethane, due to the fact that the dsm little piddly inserts do not fit a csm mount.
basically, order 2 dsm tranny mounts, and 2 dsm rear mounts.
it will work for all 4 with no or VERY minimal tramming (i had to trim nothing)
freeze the urethane bushings and lube and squish in with a vice.
PostPosted: Tue Apr 05, 2005 8:27 pm
Freeze, lube and squish with a vice. Oops left those steps out. Still worked for me though.
Users browsing this forum: No registered users and 45 guests
