Clutches... http://4g61t.org/forum/viewtopic.php?f=29&t=7543 |
Page 3 of 4 |
Author: | Flying Eagle [ Wed Jan 21, 2009 6:34 am ] |
Post subject: | Re: Clutches... |
No, that is a Cusco part made for a CC or Evo body IIRC. Got the picture on "Team4g.com". |
Author: | Mechacode [ Wed Jan 21, 2009 6:15 pm ] |
I've got this clutch ("Stage 4" F1 Racing 6 puck) mated to an AASCO 11lb aluminum flywheel. It's only faded on me once and that was because I slipped the hell out of it on a really hot day back in august. Nearing 3k miles so far. It's actually a little softer on the engagement than it was when it was brand new now that it's past the break-in period. I just remember pma1123 coming into the garage and going "why the hell did you chrome your pressure plate??". |
Author: | turbomirage89 [ Fri Jan 23, 2009 1:37 am ] |
Quote: No, that is a Cusco part made for a CC or Evo body IIRC. Got the picture on "Team4g.com".
Ok, so will that part fit on a turbo 3G CSM? If so, where can I get it? Thanks for the help!
Author: | CaptainTonus [ Fri Jan 23, 2009 1:51 am ] |
Quote: Ok, so will that part fit on a turbo 3G CSM? If so, where can I get it? Thanks for the help!
No.
Author: | Rick Ears [ Tue Mar 03, 2009 12:22 am ] |
Im running a Quartermaster AWD Twin Disc and really happy with it |
Author: | 92colt72k [ Fri Jun 26, 2009 8:49 am ] |
My friend Robert Waldrep cut a 1.3 60foot on his act 2600 with a full face clutch disc. It was not even act replacement clutch disc he got it from autozone 10.42 and 131 mph Link to his run http://www.youtube.com/watch?v=yvp1ALjAByE tyler, |
Author: | mikbik [ Tue Feb 09, 2010 7:05 am ] |
would the ACT 2100 can be use on a 4g15? anyone tried it or using that setup on their 4g15's |
Author: | CaptainTonus [ Tue Feb 09, 2010 10:39 am ] |
Quote: would the ACT 2100 can be use on a 4g15? anyone tried it or using that setup on their 4g15's
No.
Author: | quikgt [ Tue Feb 09, 2010 4:23 pm ] |
I've had the ACT 2100 3 yrs on my '63 with 350 whp and it slipped on a WOT shift into 4th last year on the strip with street tires. Also the LSD insert is starting to give up so I'll be looking at quaife and a different clutch soon. I wish money grew on trees, |
Author: | mikbik [ Thu Feb 11, 2010 8:41 am ] |
Quote: Quote: would the ACT 2100 can be use on a 4g15? anyone tried it or using that setup on their 4g15's
No. |
Author: | 6BoltColt [ Thu Feb 11, 2010 10:19 am ] |
something cheap^^ what's the difference if any, in the 6 bolt awd and fwd flywheels? im guessing the fwd is lighter?? same diameter right? |
Author: | fastvtgsx [ Thu Feb 11, 2010 10:29 am ] |
Quote: something cheap^^
No, awd flywheels are smaller.
Author: | CaptainTonus [ Thu Feb 11, 2010 10:42 am ] |
Quote: so, what will be a good upgrade clutch aside from the stock clutch you can recommed for a 4g15?
I don't think anyone makes a high performance clutch for the 4g15. Not much need for it when you make less than 100 lb/ft of torque. Maybe Centerforce makes something?
Author: | j2dapo [ Thu Feb 11, 2010 3:30 pm ] |
Quote: so, what will be a good upgrade clutch aside from the stock clutch you can recommed for a 4g15? But yeah why would you need anything more than a stock replacement for 80 hp? |
Author: | mikbik [ Thu Feb 11, 2010 6:09 pm ] |
Quote: Quote: so, what will be a good upgrade clutch aside from the stock clutch you can recommed for a 4g15? But yeah why would you need anything more than a stock replacement for 80 hp? |
Page 3 of 4 | All times are UTC-05:00 |
