It is currently Tue Apr 16, 2024 1:38 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
PostPosted: Sat Feb 07, 2004 4:12 am
what is pep boys anyway :oops: ...im always hearing about it...
PostPosted: Sat Feb 07, 2004 4:26 am
Pep boys is a chain of automotive stores... good people at the store by me.
1989 Mirage Turbo 4g63T w/ small 16g just bolted in so far.
LSD, 1g flywheel/clutch.
1989 Colt GT 4g61T (63T build in progress)
1g ECU, Injectors, Exhaust manifold, 16g evo III Turbo, SMIC, and C Exhaust cam -9*
K&N Air filter, airbox cut up, MSD plug wires, NGKs, Apexi S-AFC II, MAF translator, tubular o2 housing w/ dump tube, Full 3" mandral.
Now I ran out of fuel!!
PostPosted: Sat Feb 07, 2004 3:06 pm
Autozone/Checker(Kragen and Schuck) all carry it ^_^ I know autozone does because i bought a can last nite ^_^
01 Maxima VQ30DE
92 Summit 4g63t (Traded to Evo... R.I.P.)
I heard they ride mooses to work instead of driving cars. (About Canadians.)
PostPosted: Mon Feb 09, 2004 1:07 am
ohhh...i see
PostPosted: Mon Mar 29, 2004 11:08 pm
i have 150,943 miles on my engine. next oil change i will compression test it. then i will use restore then 2000 miles later i will check it again. the only product i use is red line injector fuel system cleaner.
thanks
PostPosted: Tue Apr 20, 2004 3:10 am
tried this stuff about 1000 miles ago in hopes that it would lessen my smoking problem, but had little faith that it would do anything....
now i can't make the car smoke when i try.
spent a couple weeks in complete disbelief every time i drove the car.
A+++
PostPosted: Tue Apr 20, 2004 3:46 am
my car only smokes if it's idleing for a long time(or i havent started itin a few days) howmuch is this "restore" lordknows i need a pil change(just after the tranny replacement)
1983 Honda VF750F
1986 Chevrolet C-10 305
1990 Chevrolet Corvette L98
1996 GMC Suburban 454
1999 Volvo S70 AWD L.P.T
PostPosted: Tue Apr 20, 2004 9:03 am
I hadnt realized so many of you have tried this product! :D I am glad to see that so many have had positive results with Restore. Heres another miracle additive i highly recommend: SeaFoam. If your lifters are tickin use this stuff! Cleans everything.
dah - why not just buy the new lifters?
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Tue Apr 20, 2004 8:40 pm
I would if i needed new lifters! If they still rattle after seafoam does its magic then i would consider it. Otherwise its a lot cheaper to clean some varnished lifters and cure it just the same :wink:
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Wed Apr 21, 2004 2:17 pm
BTW, is Restore made by LiquiMoly?
Got rabies?
PostPosted: Thu Apr 22, 2004 1:56 pm
you running updated lifters?
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Thu Apr 22, 2004 5:10 pm
all this talk brainwashed me into buying a bottle. for about six bucks what have i got to loose. i'll do a compression test and an oil change and fill you guys in on my results
1992 Galant VR-4 810/1000
PostPosted: Thu Apr 22, 2004 7:24 pm
This post talked me into trying it on my wifes beater car(Ford Tarus with 215k miles). Oil consumption went from 1 quart every 1200 miles to less than a quart down when I changed the oil at 3k. Gas milages seemed to go up a little but not really sure. I didn't put it in when I changed the oil, I wonder if there are any side effects of starting and stoping the use of it. Going to see what happenens now that I didn't add it. Greg
PostPosted: Fri Apr 23, 2004 10:07 pm
I'm not running updated lifters. The lifters tend to make the ticking noise due crap building up on them and making them stick. Seafoam cleans that crud hence no more noise. A product called Rislone works similarly. Marvel mystery oil and a slew of other products will due the same. Seafoam is my best choice based on my experience and others. Same with Restore.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
