It is currently Sat Jun 15, 2024 6:04 pm
PostPosted: Tue Dec 14, 2004 12:15 am
4g61t Delinquent
4G15 Coil Upgrade Only
installed this bad boy this weekend also. Noticed cleaner and more crisper throttle responce on my 4g15 3-spd auto. climbs in rpm a bit quicker(yes you will notice this with an auto (manuals may experience more). The coil is for a 1990-1997 Dodge "Magnum" truck and Jeep. and you will need the adapter harness from accel also in order to install this coil correctly. You also will need to use the original factory coil mounting hardware, along with the factory coil plug along with the wires from the coil. i just cut the factory coil wires at the base of the coil to give me some slack.
Heres what you need along with part numbers:
Accel Performance Coil PN: 140021
Accel Performance Adapter Harness for the 1998 and newer "Magnums"(has the plug you need to make the coil work)
PN: 140021AH
to complete this you connect the "Magnum" coil plug(the black plug in the above pic, you wont need the grey plug) and wire it to the old factory CSM coil plug wire(that you cut off the old coil). you can solder them together or just use electrical connectors. i just used round butt connectors(shut up perverts!).
after looking at both coils out along with the adapter harness youll understand what you will need and what you wont. but if you have any questions ask. and yes, im serious when i said you will notice a difference :wink:
- Paul
